Originally Posted By: earlyre
you haven't happened to swap a Cobra Rear end into your 95, for I.R.S. have you?
I ask b/c my brother just bought a (according to my dad "Shelby rear end") for his 98 GT. he has run into a slight problem, there is one part, where the "new" part uses a captive bolt in the frame, while the factory one does not have a bolt in that location.
the info he's found online, is to cut a hole from inside the trunk.
looking for a non hole cutting method to utilize.
Nope, my 95 still had a GT rear. It has 04 Cobra rear discs and calipers though. I will be pulling the rear to swap in a Torsen T2R and 3.73 gears at some point.
As far as a replacement car, she has found a 2014 Fusion Titanium AWD EcoBoost. She found a color called "Dark Side" that looks like a black base coat with green and blue flake sprayed over it. The car she found is fully loaded, so now we will dealer trade for it through my work and buy it under D-Plan.
