I am trying to determine if true or not. 1. For a 5 speed auto transmission, FNR5, the owners manual says to use only motorcraft FNR5, part# XT-9-QMM5, no prob. I understand that Mazda M5 or MV is the equivalent. I don't know if the M5 is the same as MV, it says on my dip stick M V.
Local Mazda parts doesn't know for sure. I suspect it is the same but need some way to verify. Any one know about this?
The Motorcraft is avail only at ford dealer for $10.50 per qt. Mazda dealers have M5 for 7.10 per qt. Quite a difference.
And one more thing. Does anyone know for sure if there is a transmission drain bolt on the FNR5 or will it require removing a hose?
