Folks, I am set to start changing oil on my wife's 2001 Discovery 2. Aside from getting gouged at the local Land Rover dealership, anyone know of a compatible Motorcraft or ACDelco oil filter for this beast?
Many thanks!
Many thanks!
I asked myself the same question. So, I bought one, used it for 5k miles on my VW 1.8T, then cut it open. It looked practically brand new internally. To me, it IS worth the $10.99 I have to pay for it now.quote:
Originally posted by LT4 Vette:
Are Mobil 1 oil filters worth the $9.99 ??
Yes, but the Purolator filters don't have the threaded end bypass like the Motorcraft filters do.quote:
Originally posted by N2OIL:
You could just buy a Purolator filter. They private label the Motorcraft filters too.
Actually the FL200 is the short version of the FL1A. It has the same bypass valve settings and gasket sizes. I get mine at Advance Auto for $4.68, still less expensive than Purolater's PurOnes's, plus they have the better bypass valve location and silicone ADBV.quote:
Originally posted by brianl703:
The FL-300 is the same as the PH16, both are short versions of the PH8/FL-1A.
If there's room you could use a PH8/FL-1A.
