What an ordeal !
Our '01 Nissan Patrol (4.2 litre turbo diesel) uses two oil filters, a full flow and a combination filter (by-pass and full flow).
When new with the OEM filters, the oil light would stay on for up to 8 seconds after standing overnight, not good. When we took it to a local mechanic for warranty servicing, his filters (Sakura and Nippon Max) also led to the same problem. When finally out of warranty, I took over the maintenance and used Donaldson (made in a joint venture plant in Indonesia, by the parent company of Sakura, ADR)
Finally the oil light went out in under 3 seconds after standing overnight.
But, I cross referenced those filters from another suppliers chart. I contacted Donaldson Oz who advised the correct pt. # for the full flow filter.
Uh oh.
The oil light was back to taking 8 seconds to go out. When spinning off the filter, it was bone dry. The d@mn ADBV wasn't holding.
I went through three Donaldson (out of different batches) in short order.
After glowing reviews on BITOG of Wix and their slicon ADBV, I ordered two.
Uh oh.
When they turned up, the boxes had the Wix pt. # stuck on a Sakura box, with a Sakura filter (made in Indonesia ) at over twice the price I would pay for a Sakura. As it was a special order, I had to take them
Back to 6-8 seconds for the oil light to go out. The guys from the Wix distributor wouldn't believe me and tried to tell me it was a fault with the vehicle and not the ADBV. "How come the filter is empty when I spin it off, sounds like the ADBV to me ?" He had to grudgingly agree.
I tried a Purolater, it was worse. Up to 10 seconds before the light extinguished.
This is mad.
I've tried six different filters in one oil change period !
I had a Donaldson P169071 filter in stock, a 'high efficiency' version of their Ford/Motorcraft AFL1 eqivalent (syntec media, assembled by Champion). This isn't the correct filter, as the Nissan uses a block mounted by-pass of indeterminate blow off pressure, but I thought, what have I got to lose.
I coupled it with an OEM Nissan combo filter (made in Thailand, I'm not terribly impressed with the construction of the Indonesian made Donaldsons ) during an oil change last night.
Yeee haaa, the oil light now goes out in under 2.5 seconds after standing overnight. Success ! The crazy part is this isn't an isolated case, as an awful lot of posters on a Patrol board here in Oz have experienced the same problems with OEM and aftermarket filters.
How many others have had similar experiences here ?
Is it that much to ask for an ADBV that actually functions ?
BTW, I'm still waiting for warranty on the Wix
Uh oh.
Uh oh.
This is mad.
