Our shop did this analysis on a 2006 Malibu 3.5L with 37735 on the motor. Customer stated they had the oil changed 20 miles ago at the local Chevy dealer. Brought it to us and said the motor was ticking before and after the oil change at the dealer but the dealer did not say anything about the oil condition. When we drained this oil with 20 miles on it, it looked like a heavily creamed coffee, VERY white-brown.
Our question we were looking at is if coolant was getting into the motor causing this color. We did both a hot and cold cooling system pressure test and did not loose coolant level or pressure. Head gasket testing, for combustion gases coming through the cooling system was also negative. What is the consensus on coolant on being in this system?
