My 01 Toyota Tundra has a functional oil pressure gauge where it will sit at different positions at warm or cold engine idling or when accelerating or cruising. Never heard complaints on Toyota based forums. While it's not a true graduated pressure gauge (like those diehards that plumb hot oil into the cab) I thought it's a cool feature.
Originally Posted By: Vikas
Originally Posted By: cchase
All of my vehicles have accurate temperature gauges.
Can you list your vehicles? Which scanner do you use to verify that gauge is reporting the accurate temperature?
On my Sierra the coolant temperature gauge isn't very accurate. For instance the gauge will read 70C while my Scangauge shows actual coolant temperature to be 55C
