Originally Posted By: FetchFar
The simplest oil change schedule is 6 months regardless of miles.
The one I like better is Count the number of times the car is driven less than 5 miles cold (cold defined as the car wasn't driven the previous 7 hours at least). Count 180 of those and change the oil. If either 1 year or 10,000 miles occurs first, change it.
900 mile oil changes?
That is a little farfetched.
No automaker recommends this sort of an OCI schedule, although IOLMs do account for cold starts and number of miles driven on each start.
None of them will indicate the need for an oil change after just 180 five mile trips following each cold start, though, and OEM OCIs are generally thought to be pretty conservative.
Your oil change schedule seems to be a waste of perfectly serviceable oil.
A UOA would be a better use of funds for those driving mostly short trips.
At the other extreme, 10K OCIs on a car driven on mostly longer trips following each cold start is probably reasonable, although some engines beat up their oil enough that 10K might be excessive for them.
Once again, a UOA is your friend.
