Clutch shaft seal
West Michigan
Has anybody replaced the clutch push rod oil seal on an older vintage bike, specifically the any of the Yamaha "XS" series? I developed a pretty wicked oil leak at mine after going to Mobil 1 last year (which was a mistake, for a couple reasons) and I would like to know how bad of a headache replacement will be....
Simple quick and easy. I usually use a slide hammer to pull those seals, with a #8 screw. Just keep everything clean.
Good luck
Smoky
