Oils You'd Like To See In The Future
Keep a check. Mine has had it for about a month, but last I checked they had already sold all of it with the exception of two one quart bottles.
Originally Posted By: dailydriver
A GTL based, Mobil 1 0W-30 EP with a VERY high, asteric polymer type driven VI (like 215+), and maxed out tri-nuclear moly levels, with a 12.5 + starting TBN, and a 3.2 HTHSV.
You must have had an oilgasm after you thought that one up.
I'd like to see an oil that came in only one SAE weight (5W-50), never needed changing, had a massivly high TBN, and I only needed to add oil if my engine consumed it. Oh, and it can be a pretty color too.
Oh wait, I think that happened already......
An oil that is specifically formulated for direct injection engines with base stock and additives that resist the effects of fuel,able to handle high fuel dilution especially in winter.
Originally Posted By: artificialist
Originally Posted By: Red91
Would it be possible to produce a multigrade that WILL NOT shear? I'm asking totally out of curiosity.
Some synthetic basestocks allow for a 10w30 oil with zero VIIs, and that goes a long way to preventing shear.
Amsoil has one: http://www.amsoil.com/shop/by-product/mo.../?code=ACD1G-EA
Red Line's 5W-30/10W-30/10W-40 supposedly also have NO added VIIs.
