Hi,
Been using Yamalube semi 10w40 in my 2012 Yamaha XJR1300 for the last 5k klms.Fairly ordinary oil i think as the motor is quite noisy when hot ,neutral hard to select & gearshift is not the best.
Changed over to Bell-ray full Syn 10w40 ...very pricy oil here in Australia at $110.00 for 4 litre pack.
After using this oil now for 500 klms the gear change is super smooth ,neutral is easy to select & the motor is humming quietly.
Will be changing it every 10k Klms or 12 months as per Yamaha schedule.
I'll get the oil tested after 12 months to see how it holds up..
Cheers
Cheers
