new HDM part number for lacrosse headlamp recall
by lucerne06
17 minutes 6 seconds ago
snapper blade control is stiff
by edwardh1
20 minutes 52 seconds ago
is my extension cord bad?
by motor_oil_madman
32 minutes 10 seconds ago
Done with Sandisk USB Sticks
by JHZR2
44 minutes 47 seconds ago
Pineapple Margaritas
by sleddriver
53 minutes 1 second ago
Replacing Drywall In The Bathroom (Insulation)
by Warstud
Today at 07:56 PM
351W build with a flat tappet
by ssregal39
Today at 07:30 PM
Fuel injector cleaner that will run the engine?
by Red00Jetta
Today at 07:12 PM
Car's models of 1990 and now
by HTSS_TR
Today at 07:02 PM
Another dealer oil change story
by mclasser
Today at 06:36 PM
Diagnosing HEI ignition module and ignition system
by Fsharp
Today at 05:58 PM
Spark such way?
by yvon_la
Today at 05:48 PM
hokieag07, Welder_Repairman, saredX, Corraun, kevinstoyhauler
58023 Registered Users
94 registered (Bandito440, 4WD, AZjeff, 69GTX, 74DartSport, 04SE, 7 invisible), 1585 Guests and 140 Spiders online.
58023 Members
66 Forums
249614 Topics
Page 1 of 2 1 2 >
#3346559 - 04/18/14 01:31 PM Another take on lifetime fluid - BMW ZF
CBR.worm Offline
Loc: Jupiter, Fl
First of all, I am not a believer in lifetime fluid.
We have an '08 E60 BMW W/ the ZF 6hp19(or 24?). The car has about 70k on it, I asked our dealer about a ATF change, they said it would be $1,000 and would void our warranty, but that they would do it if we really wanted to.
He explained that the fluid is a lifetime fluid, etc. I said that I did not believe in lifetime fluids and could not see any reason not to change it. He said that the fluid properties change as it ages and that the TCM compensates for these changes. He said that if you replace the fluid you have to do one of two things. One is tell the TCM to forget all learned value, the other is not do anything relative to the TCM.
He said that there are three very common failure modes for these transmissions, which is why Audi extended the warranty coverage on their vehicles with this ZF tranny.
The first is the mechatronic sleeve leaking, causing a low fluid condition and mass destruction (easy fix if caught early). The second is the mechatronic assembly (valvebody) solenoid failure, causing mass destruction in an instant with no prior signs, the third is replacing fluid and having the parameters be out of line enough that mass destruction ensues within a few thousand miles - in some cases after deleting learned values the transmission will slip and cook itself post haste.
he said the only solution is to change the fluid very regularly, or never at all.
Does anyone think there is any validity to this crazy claim of the tranny adjusting to the degrading fluid and being destroyed if new fluid is put in place? kind of a different take on the old don't ever change a high mileage ATF (which in my mind 70k is not high miles).
My inclination is to do it myself given the price, but these are kind of a pain to do. I just wanted to see if there is any validity to their claims. The tech I talked to seemed to be pretty on top of things.
'06 Infiniti G35 Sedan 6MT - 160k
#3346574 - 04/18/14 01:46 PM Re: Another take on lifetime fluid - BMW ZF [Re: CBR.worm]
The Critic Offline
Loc: Walnut Creek, CA
I thought BMW recently revised the interval to 100k for ATF. I've seem a couple of E90s with this recommendation. Are you sure that yours doesn't have the 100k recommendation in the manual?
With that said, in light duty use, I've seen a lot of cars go 150k+ on the original oil fill with no problems. Tranny failures due to oil issues are rarely proven and are not nearly as rampant as the people on this forum would like you to believe.
11 Prius - 129k - M1 EP 0w20/OE
07 Accord 2.4 - 111k - M1 5w20/FPS Filter
10 Altima 3.5 - 34k - M1 EP 5w30/FU
92 Previa - 160k - Chevron 5w30/Wix
#3346580 - 04/18/14 01:53 PM Re: Another take on lifetime fluid - BMW ZF [Re: CBR.worm]
DirkDiggler Offline
Loc: Missouri
I was told same thing on our X5. It was a CPO that had approx 60k on it when bought dec 2010. I went to dealer @ 70k to have fluid changed and they wanted $900 and said it would fail. I used "bimmer shops" search enginge, found an awesome indy, and for $300, I got all of the fluid and new filter (the entire pan is a filter). I had it done again around 110k and have it on a 30-40k change process.
'04 GMC Yukon (mine) - 213.5k miles(brew of 5 different oils between 5w and 10w30)
'13 Cadillac Escalade - 48,500 miles (currently AC Delco SynBlend)
#3346583 - 04/18/14 01:58 PM Re: Another take on lifetime fluid - BMW ZF [Re: CBR.worm]
drtyler Offline
Loc: Georgia
Here is a document from ZF that states a change interval between 80,000 and 120,000 km.
Document from ZF
After reading this, I don't see anything about resetting the computer.
Edited by drtyler (04/18/14 01:58 PM)
#3346596 - 04/18/14 02:13 PM Re: Another take on lifetime fluid - BMW ZF [Re: CBR.worm]
Miller88 Online   content
Loc: Onondaga County
$1000 for transmission fluid change?
WOW! Guess I'm lucky with $12/gallon DexIII!
Originally Posted By: 01rangerxl
A Lada with manually adjusted drum brakes sounds like a fantastic car.
2000 Cherokee / 2011 Focus
#3346624 - 04/18/14 02:49 PM Re: Another take on lifetime fluid - BMW ZF [Re: CBR.worm]
threeputtpar Offline
Loc: Appleton, WI
I'd suggest that you find another dealer that actually knows what they are talking about.
I didn't see if you were still under CPO warranty, but if you are just use the fluid that dealer stocks or Lifeguard 6 from ZF. I think Pentosin also makes a fluid for the 6HP trans. IIRC, it's actually blue in color for leak detection and aftermarket non-spec fluid identification.
If you're not under warranty, there are other fluids that are less expensive and suitable for the trans.
2013 Honda Odyssey Touring Elite - M1 5W-20 / M1-101 40k miles
2008 Ford Taurus X - Resolute 5W-20 / MC FL-400S 128k miles
#3346661 - 04/18/14 03:36 PM Re: Another take on lifetime fluid - BMW ZF [Re: CBR.worm]
dparm Offline
Loc: Chicago, IL
Talk directly to the techs for the info you need. The service advisors are just glorified salespeople.
2011 BMW M3 sedan ZCP
#3346785 - 04/18/14 06:05 PM Re: Another take on lifetime fluid - BMW ZF [Re: CBR.worm]
Ram01 Offline
Loc: New York Queens
Wow BMW is nuts 1000$ , fresh fluid is always the best
#3346834 - 04/18/14 07:07 PM Re: Another take on lifetime fluid - BMW ZF [Re: drtyler]
Wilhelm_D Offline
Loc: Tacoma, WA
Document from ZF
Yes, but be sure to use ZF LifeGuard Fluid, which retails for $14 - $21 a liter, which ZF assures us they manufacture.
On a more realistic note:
Changing the Fluid and Filter on a ZF 5HP
#3346926 - 04/18/14 08:32 PM Re: Another take on lifetime fluid - BMW ZF [Re: CBR.worm]
CBR.worm Offline
Loc: Jupiter, Fl
Yeah, I figured it was a bunch of [censored]. I was surprised that they said they would void the warranty if I paid them do it.
The vehicle in question is a CPO. Actually the CPO warranty is about to expire, so I am not to concerned about the warranty, but the tech made me nervous for sure. Maybe the techs get commission for selling new cars as well...
That document is great. I planned to order the LifeGuard 6 and do it myself. I was surprised to see that the pan/filter is plastic.
Edited by CBR.worm (04/18/14 08:34 PM)
#3350323 - 04/22/14 05:45 PM Re: Another take on lifetime fluid - BMW ZF [Re: CBR.worm]
drtyler Offline
Loc: Georgia
Here's a bit more.
Letter from ZF
Good luck with the change. There are quite a few DIYs for this job on the web. Here's one from BavAuto:
BavAuto Link
#3358949 - 05/01/14 02:37 PM Re: Another take on lifetime fluid - BMW ZF [Re: drtyler]
BSchmidt25 Offline
Loc: Milwaukee, WI
BMW E60 owner here as well ('07 530xi) with the 6HP19X. I'm about to tackle this job too. This is very useful information, so thanks to those that have shared it. What are some opinions on the fluid options for this transmission? I was looking at both Redline D6 and Amsoil ATL. Consensus seems to be that the D6 is better. Is that still accurate? Any other good options?
I was considering proactively replacing the mechatronic sleeve while I'm down there. I don't have any problems with the transmission but I know of the issues with this part. Looks like it's a pretty easy job, but has anyone else done it? Tips?
Thanks in advance.
#3360245 - 05/02/14 09:36 PM Re: Another take on lifetime fluid - BMW ZF [Re: CBR.worm]
BMWTurboDzl Offline
Loc: Atlanta,GA
I would stick with ZF LG6 as there is no compelling reason to use something else.
On a side note with regards to programming. I spoke with a ZF rep and he said it wasn't required because the mechtronics will adjust. Their own literature doesn't even mention reprogramming after an oil change.
FWIW I bought a change kit from thectsc.com and did a pan drop at 45k miles.
Edited by BMWTurboDzl (05/02/14 09:39 PM)
'15 435i - BMW branded Shell 5w30.
Prev
'10 335d
'06 330i
'03 330i
#3360766 - 05/03/14 04:04 PM Re: Another take on lifetime fluid - BMW ZF [Re: CBR.worm]
hattaresguy Offline
Loc: CT
Sure lifetime is fine, I know of a number 200k mile 722.6's that were lifetime and maybe done once if at all and still are fine. Granted that was a very good gear box but its old technology.
I'm starting to change my thinking regarding ATF changes, I have never seen an AT fail where lack of maintenance was the only factor.
I wouldn't worry about it.
Edited by hattaresguy (05/03/14 04:05 PM)
#3361528 - 05/04/14 03:10 PM Re: Another take on lifetime fluid - BMW ZF [Re: CBR.worm]
ukmastermind Offline
Loc: Los Angeles, CA
I was just talking with my friend about his E60 (528i) and how he just had the tranny replaced under warranty for abrupt shifting. The fluid was never changed and the mechaatronic devices failed twice. The fluid was never changed and it had 99k!
Page 1 of 2 1 2 >
