Originally Posted By: Roob
I agree. Toyota transmissions are very reliable. I meant that it might put the warranty at risk if the dealer knew about it.
Some only allow you to use OEM approved fluid (usually theirs) while under warranty.
Cheers.
I have no idea about Canada, could be different. In the USA if a manufacturer requires you to use their product for the warranty to remain in effect, they must provide it at no cost.
Cheers.
