5.4 3V under valve cover pics & solenoid failure
by 04SE
05/28/16 03:50 PM
New safety spec for 2017 F1 cars...
by mcrn
05/28/16 03:35 PM
M1-101 after 10k on a 95 Sunfire 2.2 OHV pushrod
by slacktide_bitog
05/28/16 03:18 PM
Base Oil Content and Marketing
by MolaKule
05/28/16 03:08 PM
Best OTC fuel injector cleaner
by 007
05/28/16 03:06 PM
A brief BMW R1100RT story
by Finn
05/28/16 02:29 PM
2015 6.7L Powerstroke Fuel Filter Change
by 2015_PSD
05/28/16 12:51 PM
Caliper question
by supton
05/28/16 12:48 PM
Impressed with Yokohama Geolander A/T G015
by K20FA5
05/28/16 12:13 PM
Need a good tire pressure guage that read over 60
by MetalSlug
05/28/16 11:55 AM
Castrol 0w40 vs M1 0w40 FS ?
by Ndx
05/28/16 11:14 AM
what old Snapper parts to save
by edwardh1
05/28/16 10:56 AM
mungchimp, troutwest66, AIRJAC3, bpete65, LEVY
58001 Registered Users
80 registered (04SE, A310, 2015_PSD, AIRJAC3, Al, 87sammy, 6 invisible), 1600 Guests and 341 Spiders online.
58001 Members
66 Forums
249530 Topics
#3346402 - 04/18/14 10:38 AM 99 Jetta 2.0 coolant drain and fill
scott37300 Offline
Loc: Wisconsin
Family member bought a 99 Jetta 2.0L and I want to go over it and freshen everything up since we don't know the service history and I'll be taking care of this car.
It says it has G12 coolant. I've never worked on a German car before so I have just about every other coolant besides that. I've read to order online since dealer is crazy expensive. Does G12 come in 50/50 mix and also concentrated bottles? I try to by the concentrated bottles and add my own water to save money.
Any special bleeding techniques for this car? I have an airlift and also lisle spill free funnel but with the reservoir tank on this car I will probably just fill "normally" unless you think either of those would work better?
Where is a good place online to order all the OEM fluids for Volkswagens? I'm going to need coolant, ATF, brake fluid, plugs, etc.
#3346411 - 04/18/14 10:45 AM Re: 99 Jetta 2.0 coolant drain and fill [Re: scott37300]
2004tdigls Offline
Loc: maple ridge, bc
#3346417 - 04/18/14 10:55 AM Re: 99 Jetta 2.0 coolant drain and fill [Re: scott37300]
dparm Offline
Loc: Chicago, IL
Some auto parts stores will carry Pentosin Pentofrost, which is what the OEM G12 stuff is:
http://www.pentosin.net/f_antifreeze.asp
2011 BMW M3 sedan ZCP
#3346436 - 04/18/14 11:16 AM Re: 99 Jetta 2.0 coolant drain and fill [Re: scott37300]
Tanama Offline
Loc: KY, USA
If you want to stick to OEM standards, you can also use Zerex G-05, it is a more readily available option.
#3346877 - 04/18/14 07:50 PM Re: 99 Jetta 2.0 coolant drain and fill [Re: dparm]
scott37300 Offline
Loc: Wisconsin
Thanks guys. Do you know if the G12 stuff comes full strength or is pre diluted 50/50? It was hard to tell from what I've found online. It looks to come full strength but I want to be 100% sure before I order it.
Also is there anything special to filling or bleeding these cars? I didn't see a bleeder screw or anything. I have an airlift and lisle spill free funnel but it looks like I can just dump the fluid in.
#3346988 - 04/18/14 09:46 PM Re: 99 Jetta 2.0 coolant drain and fill [Re: scott37300]
dparm Offline
Loc: Chicago, IL
Depends where you get it from. I believe the Pentofrost is sold as concentrate. It should be labeled clearly on the bottle.
#3371317 - 05/14/14 10:18 AM Re: 99 Jetta 2.0 coolant drain and fill [Re: scott37300]
Thermo1223 Offline
Loc: Easton, PA
I saw G12 on an Advance Auto Parts shelf the other day so check around.
Edited by Thermo1223 (05/14/14 10:18 AM)
2004 - Jetta Wagon TDI - Gone
2009 - Subaru Forester XT - 4AT 5k OCI
2013 - Ford Fiesta Slick Party Hatch Edition
#3371716 - 05/14/14 05:56 PM Re: 99 Jetta 2.0 coolant drain and fill [Re: scott37300]
FowVay Offline
Loc: Southeastern USA
It doesn't really matter in regard to the coolant but do you know if this is a 1999 model or a 1999.5 model? The '99 model is an A3 platform and the '99.5 model is an A4 platform. See if it has four wheel lugs or five.
Buying coolant from the dealership really isn't that expensive. Normally it costs about $25 per gallon but it's concentrated so this makes 2 gallons of 50/50 anti-freeze. When you buy on-line you generally get only a liter or 1.5 liters and normally pay more per ounce than the gallon jugs at the dealership.
#3372182 - 05/15/14 06:42 AM Re: 99 Jetta 2.0 coolant drain and fill [Re: Thermo1223]
Trav Offline
Loc: MA, Mittelfranken.de
+1 Pentosin SF (G12) is the correct fluid for this car. Its $15 for 1.5 litres full strength, 2 bottles will yield 6 litres of fluid 50/50. You need about 5 litres for a total fill.
No special bleeding needed, just fill the ball half full then run the engine until the fan comes on at least one time then fill to the full mark.
Do not use substitute coolants in this cooling system. G05, G11, and G12++ all contain silicates to some degree G12 does not.
