Nexus 7 to iPad Mini 4 ?
by Y_K
26 minutes 11 seconds ago
2010 camry headlights upgrade
by bmwjohn
Today at 12:02 PM
Great presentation on ATF
by Turbo_Lemming
Today at 11:59 AM
Great Presentation on Oil Filters
by Johnny2Bad
Today at 11:30 AM
long hammer drill bit
by joel95ex
Today at 11:25 AM
Mobil1HM 10w-30 vs. 10w-40 in reducing leaks
by 2James1
Today at 10:56 AM
Is this a decent price for a Honda mower
by chiefsfan1
Today at 10:31 AM
Generator special of the day HD
by LotI
Today at 10:15 AM
'15 Ecodiesel, Pennzoil Ultra Euro L 5W30, 8,330mi
by mhadden
Today at 09:46 AM
JSB Great Bearings
by artbuc
Today at 09:33 AM
fuels and GDI
by novadude
Today at 09:23 AM
P0158 2000 Jeep Cherokee 4.0
by Miller88
Today at 09:05 AM
02Maxima, xlittoninjax, Jamer, johaiti, Danielbaja
57803 Registered Users
105 registered (2010Civic, 87sammy, 2009Edge, 901Memphis, 4wheeldog, 15 invisible), 0 Guests and 0 Spiders online.
57803 Members
66 Forums
248511 Topics
#3346414 - 04/18/14 10:51 AM Typical oil pressures in an engine?
HKPolice Offline
Loc: Toronto, Canada
Seems like most filter bypass springs open up at around 12-18psi but when I google typical oil pressures, people are posting figures WAY above that. Apparently it's normal to idle around 10psi and for every 1000rpm it goes up another 10psi?
Wouldn't the filter be in bypass mode most of the time? I was under the assumption that filters don't bypass except for when the oil is really cold & thick and when near redline.
#3346416 - 04/18/14 10:55 AM Re: Typical oil pressures in an engine? [Re: HKPolice]
bepperb Offline
Loc: Milwaukee, WI
The filters open when there is a difference between the input and output sides. It doesn't matter what the total pressure is, only the difference.
So if an engine was driving down the highway with 50psi going into the filter and 48psi coming out and the bypass was 10psi it wouldn't be close to opening.
2004 Highlander 2.4
2011 Toyota Sienna 3.5
Recently Gone:
2006 Accord 2.4l K24A8
1993 Kawi EX 500
#3346420 - 04/18/14 10:59 AM Re: Typical oil pressures in an engine? [Re: HKPolice]
dparm Offline
Loc: Chicago, IL
10psi per 1000rpm is a ballpark, yes.
2011 BMW M3 sedan ZCP
#3346427 - 04/18/14 11:03 AM Re: Typical oil pressures in an engine? [Re: bepperb]
HKPolice Offline
Oh ok I get it now. Are there any figures for typical pressure drops for oil filters? Any tests to see the amount of trapped contaminates needed to cause pressure drop?
#3346466 - 04/18/14 11:33 AM Re: Typical oil pressures in an engine? [Re: HKPolice]
bepperb Offline
Loc: Milwaukee, WI
You've come to the right place. This is old but a good place to start:
http://www.bobistheoilguy.com/forums/ubbthreads.php?ubb=showflat&Number=314996
At one point someone had a similar setup in their car but I cant' find a link (I didn't look hard).
2004 Highlander 2.4
Recently Gone:
1993 Kawi EX 500
#3346558 - 04/18/14 01:31 PM Re: Typical oil pressures in an engine? [Re: HKPolice]
ZeeOSix Offline
Loc: PNW
Enjoy ... real test data from Purolator on a PureOne filter of average size (used on a 405 HP V8). As you can see, with hot oil a filter will flow lots of oil with not much pressure drop across the filter.
http://www.bobistheoilguy.com/forums/ubb...451#Post1619451
#3346563 - 04/18/14 01:32 PM Re: Typical oil pressures in an engine? [Re: HKPolice]
Realtech214 Offline
Loc: Florida
My silverado has 40psi at idle (700rpm) and about 50 in the morning at idle. With 5w30
2015 Silverado Crew Cab 5.3 LT
2001 Suburban LT
- I NEVER THOUGHT I WOULD LIKE OIL SO MUCH -
#3346573 - 04/18/14 01:45 PM Re: Typical oil pressures in an engine? [Re: HKPolice]
Zaedock Offline
Loc: Massachusetts
As mentioned, oil filters bypass with differential pressure.
This can occur when the engine is cold and the oil is viscous and it can also occur for a moment at operating temp when you go wide open throttle.
2012 F150 Ex-cab 5.0L/2004 Malibu Maxx LT
1992 YJ "The Heep"/1994 Olds Cutlass Ciera 3.1/auto
1975 Ford Bronco/1959 Willys CJ5/20XX Custom rock crawler
#3346764 - 04/18/14 05:47 PM Re: Typical oil pressures in an engine? [Re: HKPolice]
RF Overlord Offline
Loc: Cape Cod, MA
Ford modular (4.6L etc) can have 100 lbs pressure at cold startup, but settle down to 25 at hot idle. I believe this is one of the reasons Ford insisted on putting fake gauge in their cars.
Supercharged '03 Mercury Marauder - Trilogy Motorsports #61
PP 5W-30 / MC FL820S
Y2K Grand Marquis GS - daily driver
QSUD 5W-20 / MC FL820S
