Alignment will not usually cause vibration issues. It will cause tire wear, which, if severe enough, may impact the balance. Vibration felt thru the steering wheel is almost always a wheel/tire issue.
I recently had a stubborn vibration, and isolated it to one wheel... when I took it in for a re- balance, I discovered, that sure enough, the wheel was bent. It was, and usually is, on the unsupported inner lip, not visible until the wheel was on the balance machine, and not out by much ( less than. 1/4 " ) The shop got it balanced, but it took a lot of weight, but it actually runs Ok. i just threw it on the back for now, and can' t feel it at all...
Sometimes a tire can be damaged internally, and that may cause a vibration. If that's the case, there is not much you can do...except replace the tire.
