Looking for info on two quick spray waxes.........
by demarpaint
05/01/16 04:43 AM
The Heroin Epidemic In The U.S....
by qwerty1234
05/01/16 01:28 AM
Air filter wrap
by Duffyjr
04/30/16 10:21 PM
15W-40 Delo, Delvac or Rotella For KUBOTA turbo
by pburchett
04/30/16 09:50 PM
Traveler synthetic oil a slow seller?
by Electromotive
04/30/16 09:34 PM
Tyre rubber, methanol, and bore wear
by Shannow
04/30/16 09:34 PM
What to use in 99 Buick Lesabre OCI?
by Duffyjr
04/30/16 09:26 PM
Help w/Transmission Drain/Fill 08 Honda CR-V 4wd
by klt1986
04/30/16 08:58 PM
pennzoil ultra platinum pure plus
by Brayden
04/30/16 08:10 PM
Group 5 synthetic oil
by Brayden
04/30/16 08:07 PM
Pennzoil Ultra platinum at Walmart
by RubentheIowan
04/30/16 08:03 PM
G-05 Change intervals, 3 or 5 years?
by Canadastang
04/30/16 08:03 PM
Doxxy, Jetstreamz06, TalNum, Spinnizle, JustinL
57758 Registered Users
16 registered (eddy21, Bookmaker, bmod305, billt460, FFeng7, 1 invisible), 615 Guests and 115 Spiders online.
57758 Members
66 Forums
248282 Topics
Page 1 of 3 1 2 3 >
#3346042 - 04/17/14 10:06 PM OE spark plug question
jorton Offline
Loc: San Antonio, TX
Do I have to replace spark plugs with OE parts?
Nickel alloy electrode wears fast. The other car has the same type COP ignition and OE parts are platinum. Platinum electrode wears longer. If I decide to run platinum plugs I will still change them at manufacturers 32,000 miles intervals.
Edited by jorton (04/17/14 10:10 PM)
"If everything seems under control, you're just not going fast enough."
- Mario Andretti
#3346051 - 04/17/14 10:13 PM Re: OE spark plug question [Re: jorton]
crazyoildude Offline
Loc: New Jersey
when we rebuild engines we only use oem plugs... oem was tried and tested.
In Automotive class when i was a kid i had a shop teacher that always said ..Its Nice To Be Nice! That is one thing i always remembered..
#3346053 - 04/17/14 10:15 PM Re: OE spark plug question [Re: jorton]
artificialist Offline
Loc: Florida
Sometimes you can get away with different spark plugs, sometimes you can't. Look for a TSB that may call for a different plug than the exact OEM plug.
I remember back when I had my Saturn ION, double platinum plugs were OE, and the manual said to only use that kind of double platinum plug. I order new ones from a dealer, and I was sent iridium plugs.
Toyota did this as well. At one time, the 1MZ-FE engine took some weird dual electrode plugs, but eventually, they were superceded by a simple single electrode iridium plug.
2010 Lancer Ralliart Sportback
#3346054 - 04/17/14 10:15 PM Re: OE spark plug question [Re: jorton]
salv Offline
Loc: Cadyville, NY
OEM is best.
2003 Trailblazer: Mobil Super HM 5w30 L25288
2000 Ford Focus Wagon: Mobil Super 5000 DW-5230
#3346078 - 04/17/14 10:52 PM Re: OE spark plug question [Re: salv]
zrxkawboy Offline
Loc: SD
Originally Posted By: salv
OEM is best.
+1. I learned this the hard way.
"Think of all the Ford owners who will someday want an automobile." John Dodge
#3346084 - 04/17/14 11:05 PM Re: OE spark plug question [Re: jorton]
bvance554 Offline
Loc: VA
Then just run the OEM plugs. That completely defeats the purpose of running a platinum plug.
#3346109 - 04/17/14 11:40 PM Re: OE spark plug question [Re: jorton]
901Memphis Offline
Loc: Northern Kentucky
If they are easy to change go OEM, replacing plugs on a 4 cylinder is a cake walk, if its a hard to reach v6, go with laser iridium of the same manufacture. NGK Laser Iridium would probably work great in your engine.
2002 Buick Century 125k - Built 4T65e(Maxlife) - M1 0w40 /Fram Ultra XG 3387A
1998 Nissan Altima 335k - 5MT - M1 HM 5w30/Fram Ultra XG7317+MOS+ATP 205
#3346150 - 04/18/14 04:20 AM Re: OE spark plug question [Re: jorton]
PandaBear Offline
Loc: Silicon Valley
It depends. I tried different plugs and sometimes it is better and sometimes it is worse. For easy to change 4 cylinders I throw whatever I feel like and they usually works well, but for hard to change V6s, I'd not play around and use only OEM, so I don't need to worry about doing it again.
"You keep asking questions PandaBear and you'll end up a vegetarian like my wife" - Camu Mahubah
#3346179 - 04/18/14 06:09 AM Re: OE spark plug question [Re: jorton]
jorton Offline
Doesn't fuel economy go down when electrodes are worn? At 26,000 miles I see worn electrodes with the naked eye. This Patriot gets 24mpg highway, and it's underpowered. 3000 pounds is too heavy for 2.0l. I think I can improve performance by running a longer wearing spark plug.
Edited by jorton (04/18/14 06:10 AM)
- Mario Andretti
#3346201 - 04/18/14 07:01 AM Re: OE spark plug question [Re: jorton]
Kira Offline
Loc: Champlain/Hudson Valley
Hello, You cannot improve performance with a longer lasting plug. It doesn't work that way.
The only thing which MIGHT help is if the spark itself could be made bigger.
Years back there were "Thunderbolt" ignition coils which simply upped the secondary voltage.
My very first car had such a system. There were DANGER HIGH VOLTAGE stickers under the hood but I couldn't see anything different.
I called the previous owner and he said the mod worked so well he transferred it to his new car.
I jumped the ballast resistor (it had burnt out) in an old Toyota I had. The upped voltage burnt points faster but it did improve the performance noticeably.
Now-a-days stick with stock. Kira
#3346208 - 04/18/14 07:13 AM Re: OE spark plug question [Re: jorton]
Donald Offline
Loc: Upstate NY
NGK makes excellent plugs. I would use them if OEM. But I also think you can upgrade.
2015 Ford F250 w/Powerstroke
2001 Jeep Grand Cherokee Laredo 4.0- 4-sale
1999 Dodge Ram 2500 w/Cummins- 4-sale
#3346222 - 04/18/14 07:42 AM Re: OE spark plug question [Re: jorton]
The_Eric Offline
Loc: Iowa
If you're going to change out plugs at the short OE interval, then don't waste money on a double platinum or iridium plug.
If you are entertaining extending the service interval, then by all means, run a double platinum or iridium plug (the correct for application plug that it is).
2001 Hyundai Elantra 2.0
1998 Chevy Malibu 2.4
1995 Pontiac Grand Am 3.1
1979 Ford F-150 351M
#3346227 - 04/18/14 07:47 AM Re: OE spark plug question [Re: jorton]
asand1 Offline
Loc: Oregon coast
Stick with oem brand, but feel free to upgrade electrode material. If you have waste spark ignition you will need double platinum or double iridium.
Sometimes when switching brands, there is something lost in the translation resulting in a hotter or colder plug. This can cause a miss or detonation.
Nissan/Infinity/Mazda Manuals
1996 Maxima 310K
2008 Uplander 80K
#3346273 - 04/18/14 08:41 AM Re: OE spark plug question [Re: jorton]
BigCahuna Offline
Loc: Deep in the heart of Jersey
Since no auto mfgr actually MAKES spark plugs, No one can prove they are the best. Harley plugs are a classic example. They're made by Champion, who also sells a plug that looks exactly the same, without the Harley name on it for less $$$. With the way cars are made these days, computers control every aspect of ignition. A super duper factory trained tech could not tell just from driving a particular car ,what plugs are installed in it.Use whatever brand you want, as long as the plug mfgr says it's for your vehicle. And change them every 50-100k miles.,,
#3346284 - 04/18/14 08:52 AM Re: OE spark plug question [Re: 901Memphis]
ARCOgraphite Offline
Loc: N.H, U.S.A.
+1 on Ir with COP - much less misfiring. and you can go 80K on the plugs easy.
2014 Nissan Rogue S CVT, OC#4 13740mi-Castrol Magnetec 5W30+Nissan 15208-9E01A Filter
2015 Forester 6MT 5Door, OC#4 24596mi-PP 0W20+Subaru Filter
Page 1 of 3 1 2 3 >
