400C temperatures would be about as common in any unmodified factory engine as teeth are in hens.
This is a clasic example of setting up a test not sanctioned by any recognized body and then declaring that your product won while other products lost.
Probably means nothing.
Why does anyone think that Castrol Edge is a Grp IV oil anyway?
Also, IIRC, LL-04 is the low-SAPS spec and is intended for diesels in this country.
LL-98 or LL-01 would have been better oils to have tested Edge against.
Finally, the BMW labeled Castrol is hardly the only oil out there.
As others have noted, there are other oils that meet the Honda turbo spec.
These were not "tested", of course.
