GM to test self-driving taxis
by xfactor9
05/06/16 01:09 AM
Resurfacing Brake Rotors
by The Critic
05/06/16 12:02 AM
Largest M1 filter for Jeep 4.0
by ARMY_Guy
05/05/16 10:50 PM
Mobil 1 or Castrol edge?
by sky06
05/05/16 09:48 PM
1 piece lug nut recommendations?
by dlundblad
05/05/16 09:07 PM
1996 Chrysler Coolant
by outoforder
05/05/16 09:02 PM
Hat Tip to RMEuropean
by sleddriver
05/05/16 08:54 PM
Toro OHV considered flat tappet type...
by Duffyjr
05/05/16 08:48 PM
Tire Rack now carries the Falken Azenis RT615k
by slacktide_bitog
05/05/16 07:30 PM
Walmart now carries Nokian tires
by slacktide_bitog
05/05/16 07:16 PM
Heater Core Leak?
by bprat318
05/05/16 06:54 PM
R2C air filters
by Srt20
05/05/16 05:55 PM
waldawg, Defcon, drivingaford, funkyheff, Ralph62
57814 Registered Users
23 registered (Boczech, alcyon, Doug Hillary, carlprop, 4 invisible), 1 Guest and 0 Spiders online.
57814 Members
66 Forums
248535 Topics
Page 1 of 2 1 2 >
#3345846 - 04/17/14 06:55 PM Pennzoil Platinum 8150 miles Cruze 1.4
mwball0 Offline
Loc: Ky
Here are the results from my 2013 Cruze. TBN didn't hold up very well but everything else looks OK to me. What do you think? OLM at -0 by about 800 miles.
Miles on vehicle 26500
Miles on Oil 8150
ALUMINUM 15
CHROMIUM 0
IRON 15
COPPER 1
LEAD 0
TIN 0
MOLYBDENUM 55
NICKEL 0
MANGANESE 15
SILVER 0
TITANIUM 0
POTASSIUM 14
BORON 18
SILICON 10
SODIUM 6
CALCIUM 2322
MAGNESIUM 19
PHOSPHORUS 659
ZINC 798
BARIUM 18
WATER 0
Viscosity 10.6
TBN 1.7
#3345870 - 04/17/14 07:31 PM Re: Pennzoil Platinum 8150 miles Cruze 1.4 [Re: mwball0]
MuzzleFlash40 Offline
Loc: Ohio
Seems to look pretty good. Oil is done, but it is D.I. Running the OLM to %0 on this oil is just fine.
15 Ram Big Horn 4x4 5.7-19k
DuraMAX Syn 5w20 & Mopar
16 Santa Fe Sport AWD 2.4-25k
Cam2 SynBlend 5w20 & OEM
#3345873 - 04/17/14 07:34 PM Re: Pennzoil Platinum 8150 miles Cruze 1.4 [Re: mwball0]
mattwithcats Offline
Loc: Virginia
The Cruze 1.4 is a turbo, I would not let the olm go past 25%
2009 Smart Pure
Pennzoil Platinum Euro 0W-40
Purolator Synthetic PSL 14610
175/55R15 tires...
#3345899 - 04/17/14 07:59 PM Re: Pennzoil Platinum 8150 miles Cruze 1.4 [Re: mwball0]
Tucson Five-O Offline
Loc: Tucson, AZ
MuzzleFlash40,
The 1.4L Turbo engine is port injected, although it is interesting that there was a positive reading for manganese which is usually only seen in DI engines.
And for MY2013 GM reduced the OLM interval.
And mattwithcats,
This UOA looks fine. Wear looks good, viscosity is excellent, TBN of 1.7 is good, using the Blackstone standard. With the revised OLM calibration, you can run it down to 0% (OP ran his 800 miles past 0%). Just use a good synthetic.
I have a ~7650 mile QSUD UOA I'm waiting for results from Blackstone which I anticipate will be fine also.
Take care,
Gary
2013 Summit White Chevrolet Cruze Eco 6AT 38k miles M1 0W-30 AFE/OEM (ACDelco/Hengst), VML ATF, Goodyear Assurance Fuel-Max
#3345922 - 04/17/14 08:19 PM Re: Pennzoil Platinum 8150 miles Cruze 1.4 [Re: mwball0]
sciphi Offline
Loc: Upstate NY
Change it at 7500 miles next time. Based on previous UOA's I've done on my 1.4T Cruze, 7500-8000 miles seems to be when to change the oil in these cars.
2009 Honda Fit Sport
2012 Chevrolet Cruze Eco
#3345946 - 04/17/14 08:47 PM Re: Pennzoil Platinum 8150 miles Cruze 1.4 [Re: mwball0]
Ram01 Offline
Loc: New York Queens
You better off using castrol gtx syn blend with those results PP ain't cutting it in that little 1.4 motor
#3345969 - 04/17/14 09:13 PM Re: Pennzoil Platinum 8150 miles Cruze 1.4 [Re: Ram01]
DirtyMoe21 Offline
Loc: Fort Worth,Texas
Looks like it is doing just fine to me.
2005 Toyota 4-Runner 4x4 4.7L 136.7k
Mobil 1 0w-20 AFE/Fram Ultra XG3614
2010 Toyota Corolla S 1.8L 81.3k
Mobil 1 0w-20 AFE/Toyota OEM Filter
#3345991 - 04/17/14 09:29 PM Re: Pennzoil Platinum 8150 miles Cruze 1.4 [Re: mwball0]
Cooper Offline
Loc: Mid-West, USA
What weight of Pennzoil Platinum did you use?
2012 Nissan Xterra
2014 Subaru Forester
PENNZOIL ULTRA PLATINUM
#3346026 - 04/17/14 09:46 PM Re: Pennzoil Platinum 8150 miles Cruze 1.4 [Re: mwball0]
lawman1909 Offline
Loc: USA
I wouldn't take the OLM to 0% on the 1.4 Turbo. I wouldn't even go past 20-25% with those little turbos whining like they do.
2014 Honda CR-V AWD LX
M1 0W-20 EP/Fram Ultra 7317
Bless all LEO's, Fire, EMS, and military personnel both active and retired. USA! USA!
#3346116 - 04/18/14 12:16 AM Re: Pennzoil Platinum 8150 miles Cruze 1.4 [Re: mwball0]
dustyroads Offline
Loc: upstate NY
Looks excellent to me. The aluminum should trend downward as the engine breaks in. The engine had only 18k on it when that oil went in. Almost no copper corrosion as the tbn is still good. Viscosity looks good (assuming it was 30 grade oil).
Don't see anything wrong with it.
2011 Taurus sel
QSGB 5W20 MC FL500S
#3346216 - 04/18/14 07:31 AM Re: Pennzoil Platinum 8150 miles Cruze 1.4 [Re: sciphi]
mwball0 Offline
Loc: Ky
I agree, going to stick with around 7k from now on.
#3346217 - 04/18/14 07:32 AM Re: Pennzoil Platinum 8150 miles Cruze 1.4 [Re: Cooper]
mwball0 Offline
Loc: Ky
5W30
#3346348 - 04/18/14 09:50 AM Re: Pennzoil Platinum 8150 miles Cruze 1.4 [Re: mwball0]
sciphi Offline
Loc: Upstate NY
Was this the old formula PP or the new formula made from natural gas?
#3346789 - 04/18/14 06:07 PM Re: Pennzoil Platinum 8150 miles Cruze 1.4 [Re: mwball0]
addyguy Offline
Loc: Canada
Al is way, way too high for my liking. Under 5 ppm is ballpark...high Al means severe piston wear or 'piston scuffing'. I'd shorten the OCI for sure.
2003 Mazda Tribute LX V-6, 196,850 miles...DEAD.
MM F1 5W-20 conventional + Bardahl + top-offs.
MM MPH2 filter.
#3346795 - 04/18/14 06:18 PM Re: Pennzoil Platinum 8150 miles Cruze 1.4 [Re: sciphi]
mwball0 Offline
Loc: Ky
Don't know for sure but I suspect it was the new formula. It was purchased in the fall of 13, they started bottling the new formula back last year at some point far before the advertizing started and the bottle changed.
Page 1 of 2 1 2 >
