Originally Posted By: Thermo1223
Originally Posted By: ls1mike
I think everyone's definition of reliable is different. Little things don't bother me. I prefer having not to adjust valves, do timing belts or worry about large maintenance items like that.
Exactly, I actually prefer a belt to a convoluted timing chain setup which I can't fix myself.
I like the idea of replacing parts in that area before they fail which is why you always replace the waterpump on a timing belt setup IMO. At least if it is a quality replacement part not something from china.
Timing chains usually never have to be touched though, and last the lifetime of the vehicle. Timing belts need to be replaced at certain intervals, and while on some cars they are easy to access, others are a major pain.
I do agree with replacing wear parts in a certain area when they become easy to replace. For example, when I first bought my Jeep it overheated. The previous owner barely changed the oil, and never touched the cooling system. While replacing the radiator, I did the waterpump, hoses, fan clutch, and thermostat since they were easy to access with the radiator off.
