Originally Posted By: asand1
Originally Posted By: Vikas
which side of the cluster is the illuminated check engine light?
Its not on this week, however I have had an intermittent CEL for evap.
Unfortunately I don't know the maintenance history.
I took my 98 Max from around 63k to about 210k+ and I only had a couple of problems:
1) I had to replace the evap purge valve, I guess it's located in a bad spot and ends up getting rusted up.
2) I had a problem with an injector leaking down. It would take a long time to start and then blow black smoke at startup. I had a "fuel injector clean" done at a local shop and it fixed it.
3) Had to replace the radiator fans and the cabin fan.
The motor LOOKS familiar, but I never really got to know it because I never had to work on it.
I weighed mine (1998 SE auto) and it was right at 3000 pounds.
