Can anyone tell me if Maxlife ATF is suitable for use in a 2008 VW Beetle 2.5l Auto? The data sheet lists a couple of different Vw numbers but I'm having a hard time finding out what this car should use.
The car has 146k on the odo, and I don't believe that the trans fluid (or any fluids for that matter aside from engine oil) has ever been changed. I was planning on doing a couple of drain and fills on the transmission over the next few thousand miles.
If the Maxlife is not acceptable to use, can someone recommend another option? Not familiar with VW's and the owners manual doesn't even really list fluid specs other than the 502 oil, g12 coolant and dot 4 brake fluid. I am also looking for a coolant as well as power steering fluid to use.
Thanks
Thanks
