Originally Posted By: Rtstrider
Any advice for the 7afe engine? Reading it's a known oil burner. Would running Mobil1 Syn 10w 30 not be recommended? I'm reading quite a few people having decent results with Maxlife 10w 40 (which seems pretty thick)
I have a 94 Corolla 7AFE with a 5 speed manual. I would not run synthetic oil as they do like to consume oil, especially if you beat on it which you have to to keep up with traffic. Use a high mileage 5w-30 or 10w-30.
As far as the manual transaxle fluid, I've tried everything, to include GL-4 synthetics. The best feeling fluid combination I've used is Valvoline GL-5 with a bottle of Lubegard gear fluid supplement.
As far as other maintenance, pull a spark plug and check the condition. Check the belts; they are manually adjusted, don't get them too tight. Pop the top timing cover off and check the timing belt. If the plugs need replacing, throw a new cap and rotor on it.
Antifreeze; if it's red, continue using the old school Toyota red (not pink) antifreeze if you can find it; if not, I'd switch it to Zerex Asian formula.
Clutch "fluid" is brake fluid. I wouldn't screw with it because at 200K miles, you will likely be putting new clutch hydraulics in it in the near future. In fact, if the pedal ever feels a bit soft of like you have to give it an extra pump some mornings for the clutch to feel good, pull the rubber boot off the slave cylinder. Fluid will likely dribble out meaning the slave cylinder needs replacing. I just did both the slave and master on mine 3 weeks ago.
Fuel filter is below the brake master cylinder on the firewall. It's a royal PITA to change; you need long extensions and the vehicle on stands to get at the underside of it.
Everything else is very easy to work on.
