Industrial hand cleaners?
by KenO
07/26/16 11:58 PM
Shell Rotella T6 in a Altima 2.5
by Grambo
07/26/16 11:24 PM
"Creaking" Conti DWS's?
by Lolvoguy
07/26/16 10:52 PM
Check your car after it's been worked on
by Nick1994
07/26/16 10:15 PM
How are lg android devices now days?
by ram_man
07/26/16 09:42 PM
Dexos 5w30 with highest 100c Viscosity
by CapitalTruck
07/26/16 09:32 PM
How do you avoid being perceived as a rookie when
by motor_oil_madman
07/26/16 09:27 PM
Oil opinions after dumping FF
by JoelB
07/26/16 09:27 PM
Bulk loading a grease gun?
by buck91
07/26/16 08:59 PM
Sears Battery Pricing
by PeterGreen
07/26/16 08:29 PM
My 12am emergency strut spring repair on a Civic
by Colt45ws
07/26/16 08:19 PM
My upper sidewall pinehole leak fix
by Pokermatters
07/26/16 07:52 PM
snydercn, surfbum, Tmemz4, woollum86, Phil108
58612 Registered Users
55 registered (AIRJAC3, 4WD, 2015_PSD, AZjeff, AirgunSavant, acbent, 5 invisible), 1051 Guests and 14 Spiders online.
58612 Members
66 Forums
252296 Topics
Page 1 of 2 1 2 >
#3344010 - 04/15/14 10:01 PM what is friction modifer/limited slip additive?
1 FMF Offline
Loc: CT
what is it chemically, or what ingredients are in friction modifier for gear oils?
#3344025 - 04/15/14 10:11 PM Re: what is friction modifer/limited slip additive? [Re: 1 FMF]
Joe_Power Offline
Loc: USA - Coast to Coast, Border t...
2011 Jeep Wrangler
2015 Chevrolet 2500HD LTZ
2011 Harley Davidson FLHX
Common sense is a flower that doesn't bloom in everybody's garden.
#3344052 - 04/15/14 10:39 PM Re: what is friction modifer/limited slip additive? [Re: 1 FMF]
1 FMF Offline
Loc: CT
i've not easily finding anywhere stating what friction modifier actually is made of.
i'm assuming they are all made of a similar type of oil and set of additives. is limited slip additive from ford, gm, royal purple, amsoil, redline all the same or are they completely different ?
http://en.wikipedia.org/wiki/Friction_modifier
all it says is glycerol mono-oleate is a "common" friction modifier. what are some others?
#3344058 - 04/15/14 10:44 PM Re: what is friction modifer/limited slip additive? [Re: 1 FMF]
Clevy Offline
Loc: Saskatoon canada
Isn't the ford stuff graphite?
2006 Charger RT
Miles x 2 per oil filter
#3344073 - 04/15/14 11:02 PM Re: what is friction modifer/limited slip additive? [Re: 1 FMF]
MolaKule Offline
Loc: Iowegia - USA
The limited slip additives for differentials are not the same as PCMO friction modifers, is not the same as ATF friction modifiers, is not the same as MT, etc.
Limited slip additives are made of base oils and specialized chemistry, but most are similar in composition.
Wiki authors generally have no idea what it takes to make a lubricant.
Edited by MolaKule (04/15/14 11:15 PM)
Life begins at the end of your comfort zone. smile
#3344108 - 04/16/14 12:16 AM Re: what is friction modifer/limited slip additive? [Re: 1 FMF]
1 FMF Offline
Loc: CT
i was looking to find out what friction modifier is made of specifically for gear oils in differentials.
can you tell me what it is, or is it proprietary trade secret stuff that isn't disclosed ?
if i go to walmart or autozone and buy a cheap bottle of limited slip additive for gear oil for axle differentials, what's it made of?
#3344136 - 04/16/14 02:24 AM Re: what is friction modifer/limited slip additive? [Re: 1 FMF]
Marco620 Offline
Loc: Midwest, Rural KS
Probably no moly as that would cause less friction. Each company is probably be hush on what secret ingredient they use.
#3344142 - 04/16/14 02:50 AM Re: what is friction modifer/limited slip additive? [Re: Marco620]
Clevy Offline
The ford friction modifier for gears is graphite. I'm almost positive.
Redline shockproof is made for gear sets. I know its loaded with moly and zddp. And it's an ester too so I'm assuming the competition is fierce for space.
Makes total sense to me the more I consider how an oil formulator has to consider what each element does and how each re-acts with another,then how does each compound re-act with other elements and compounds.
Certainly a balancing act. Knowing each elements assets and liabilities and using another to compensate for another compounds weaknesses.
It's an exacting science for sure.
I'm almost to the point that the only oil additives I will actually stock are ceratec,mos2 and motor oil saver.
2006 Charger RT
#3344188 - 04/16/14 06:08 AM Re: what is friction modifer/limited slip additive? [Re: 1 FMF]
Corvette Owner Offline
Loc: Waldorf, Maryland
It used to be whale oil, but they changed it!
Vehicles:
98 Corvette
06 Murano
96 Chevy Van (Custom Conversion)
14 Chevy Impala
10 Starcraft Boat
13 Buick Enclave
#3344530 - 04/16/14 12:54 PM Re: what is friction modifer/limited slip additive? [Re: 1 FMF]
MolaKule Offline
Loc: Iowegia - USA
The formulations and exact chemical constiuents are proprietary.
I am not sure what you mean by cheap. A limited number of blenders make most most of the LSA's you see on the shelves.
Edited by MolaKule (04/16/14 12:57 PM)
#3345096 - 04/16/14 10:06 PM Re: what is friction modifer/limited slip additive? [Re: 1 FMF]
1 FMF Offline
Loc: CT
by cheap i mean something off the shelf at autozone or advance auto that was a no name brand,
http://shop.advanceautoparts.com/p/k-w-c...hTerm=posi-trac
https://www.google.com/#q=limited+slip+friction+modifier&tbm=shop
if the links work, for rear axle differentials there is motorcraft stuff as cheap as $6.22 a bottle.
stuff from advance auto is less than $10.
from google shop it shows stuff from auburn gear for $15.
$8.10 http://www.amsoil.com/shop/by-product/gear-lube/slip-lock-gear-oil-additive/
so back to my very first question,
some people say use the ford additive it works best, others say get stuff from gm, and there's mopar, yukon, auburn, amsoil, redline, royal purple.... to name a few.
why would i choose one of those versus something off the shelf at walmart or whatever's at the local parts store?
#3345140 - 04/16/14 10:41 PM Re: what is friction modifer/limited slip additive? [Re: 1 FMF]
MolaKule Offline
Loc: Iowegia - USA
If you are asking for a recommendation, I would choose whatever is local and the cheapest.
#3345215 - 04/17/14 02:50 AM Re: what is friction modifer/limited slip additive? [Re: Corvette Owner]
turtlevette Offline
Loc: Massachusetts
Yea, old timers think the whale oil is the only good stuff. Pretty shameful that they ever used that. It might be old man's tales.
I don't use limited slip additive. Why reduce the effectiveness of the system? I want it to grab hard when the right wheel starts to spin. Clutch popping sounds cool. Back end getting twitchy is also cool.
#3345635 - 04/17/14 01:40 PM Re: what is friction modifer/limited slip additive? [Re: turtlevette]
MolaKule Offline
Loc: Iowegia - USA
Someday you will be an old F**rt too! grin2
There is a branch of chemistry called LIPIDS, with a subbranch called, marine-oil triglycerides. You might want to Google it.
The marine oil extracted for lubricants was Whale oil (which we have discussed here a least 12 times in this forum alone), or more accurately, Sperm Whale oil, from the spermiceli organ and which contains mostly liquid wax esters and some triglycerides.
This liquid Wax ester was primarily used in ATF fluids as friction modifiers because they were what was needed at the time and had quite good oxidation resistance.
Today, the liquid wax esters are synthesized by reacting euricic acid or other comparable acid(s) with specialized alcohols.
The euricic acid is derived by the fractioning of rapeseed feedstock oils.
I pity those poor rapeseed plants for having to endure this victimization. frown I am sure the Gaiaon's would not approve of this process as well.
With your comprehensive mechanical background, I am sure you are aware of something called, "stick-slip," which is not to be confused with "slap-stick" comedy. grin2
This a sudden jump in relative sliding velocities which can cause excessive wear in Limited Slip Differential clutching mechanisms.
LSD additives reduce or eliminate the "stick-slip" action in order to reduce mechanism wear.
I always recommend adding 1/4 of a tube increments of LSD FM additive to the differential lube, and then testing doing figure eights to determine if stick-slip has been reduced or has disappeared.
I.E., use only enough LSD FM to make the stick-slip vanish.
Edited by MolaKule (04/17/14 01:49 PM)
#3346449 - 04/18/14 11:23 AM Re: what is friction modifer/limited slip additive? [Re: MolaKule]
fpracha Offline
Loc: MA
So it is not good for use in engine oils ?
Page 1 of 2 1 2 >
