Originally Posted By: Trav
Strange as they are not in the same the same area of the case. There are 3 heater hoses, drivers, passengers and the return.
These IIRC use worm clamps, make sure they are tight. Check all worm clamps for tightness.
Are you sure its coolant coming out of the A/C drain or could it be running down the outside of it?
It is unusual not to get at least a slight film on the inside of the windshield when you have a leaking core.
There is a pipe on the core held by 2 bolts inside the case if this was leaking at the joint it seems possible for it just to leak out the bottom of the case.
The stop leak should have no problem sealing this up permanently, its a corroded core that is more of a problem but they tend to leak badly and fog the inside of the windshield and get worse quickly.
Check the clamps and drive it. I am optimistic.
Trav, Thanks will check everything tomorrow especially the source underneath. I had a leak in the heater hose area before. It was the aux water pump. replaced and all was good. Does not seem to be the same. However a hose of the heater valve could be leaking. No obvious film on the windows.
No apparent leaking from the heater valve/pump area. clamps are tight. Cannot see any leakage under car when parked after driving. Coolant level seems OK. This is after I added 4 tabs of the GM product and drove around with the heater full blast. We shall see.
You might have successfully stopped a small leak! Keep us posted.
