I have two Toyotas. 2003 corolla and a 2004 Rav4 AWD. Both have Type IV fluid that says the ATF is good for the life of the car under normal conditions. At about 50k miles on each one, the local JiffyLube guys said the ATF was burnt and needed to be flushed. So, took them to the local auto repair place and they said the ATF looked and smelled fine. No work needed. Same thing happened at 100k miles at jiffyLube but this time I took to a transmission shop. Again they said the fluid was fine; no work needed. At 150k miles again the jifflube guys said to change the ATF. Took them to another tranny shop. This shop said it was not wise to change fluid or do any maintenance on the tranny at 150k miles. I know the owner of the shop and he said to just let it be and throw in some Lucas if it acts up. I know a guy that owns his own auto repair facility and he also said to let the trannys be; they should make it to 300k miles.
As I read many of these posts I'm curious what people on here consider to be "lifetime" as defined by Toyota. With the frequent ATF change intervals that I see on this forum, how many miles are you hoping to get out of your cars? Or worded another way, what is the minimum miles you'd be satisfied with considering your maintenance program?
(PS I get the oil changed every 3-5k miles)
The Corolla has 202k miles and the Rav4 has 243k miles. Still going strong and never been in the shop except for brakes and tires and a coolant flush a couple years ago.
