Tundra steering wheel
by RN89
08/25/16 08:11 PM
98-02 Corolla and Oil Consumption
by mmorri16
08/25/16 08:10 PM
How does fuel dilution affect HTHS viscosity?
by HKPolice
08/25/16 07:58 PM
Volkswagen bets big on EV(Electric Vehicle)
by HTSS_TR
08/25/16 07:50 PM
Did I goof?
by mv6845
08/25/16 07:33 PM
Opinions on Indestro tools?
by Vern_in_IL
08/25/16 07:25 PM
Nice bear sighting
by car51
08/25/16 07:05 PM
Non-directional performance winter tires 205/65-15
by slacktide_bitog
08/25/16 06:14 PM
Is there a market for a used tool box? w/Pics
by Jimmy9190
08/25/16 05:18 PM
Review of Sangrean Weather Radio CL-100
by chiefsfan1
08/25/16 05:18 PM
Round holes AND louvers! Oh the humanity!
by Nick1994
08/25/16 04:20 PM
Should I change the oil when changing spark plugs?
by THafeez
08/25/16 04:08 PM
sledhead1, AtillatheHunk, Goofball1205, Djlmedic, BigHoss256
58926 Registered Users
117 registered (B320i, 2015_PSD, 01rangerxl, 2002 Maxima SE, 2009Edge, Alex_V, 15 invisible), 1540 Guests and 6 Spiders online.
58926 Members
66 Forums
253559 Topics
Page 1 of 2 1 2 >
#3342061 - 04/14/14 12:52 AM VW Passat- Amsoil does not make a gear lube
smokey422 Offline
Loc: Marshall, MO USA
We have a 2014 VW Passat that I love with the 5 speed manual shift and although Amsoil makes an approved motor oil, they don't have an approved gear lube. I like Amsoil gear lubes ever since the first change I put in my 1983 Ford Ranger 4 speed manual pickup. Does anyone know if Amsoil plans on making a gear lube for my Passat?
#3342083 - 04/14/14 02:13 AM Re: VW Passat- Amsoil does not make a gear lube [Re: smokey422]
Olas Offline
Loc: Manchester, England
Nope, they don't.
Redline, Millers, or Fuchs (in that order) are my preferred fluids for VW gearboxes.
1982 VW Scirocco
1457cc
98 bhp
78000 miles
Redline fluids
Mann/Mahle filters
#3343090 - 04/15/14 12:01 AM Re: VW Passat- Amsoil does not make a gear lube [Re: smokey422]
Mr_Accord Offline
Loc: LBP
I went with redline in my 5spd 99 Golf and I couldn't be happier.
Edited by Mr_Accord (04/15/14 12:01 AM)
1990 VW Jetta GL 1.8L 8V - SOLD
1992 Honda Accord Lx - SOLD frown
1993 Ford Aerostar XL 4L V6 - Retired RIP
2004 SAAB 9-3 ARC 2.0T - Current
#3343127 - 04/15/14 03:22 AM Re: VW Passat- Amsoil does not make a gear lube [Re: Mr_Accord]
smokey422 Offline
Thanks for the replies. We're not due for a while yet but sounds like it will be Redline!
#3343292 - 04/15/14 09:17 AM Re: VW Passat- Amsoil does not make a gear lube [Re: smokey422]
147_Grain Offline
Loc: USA
I second the use of Redline. Looks like you may need a GL-4 synthetic lubricant that's similar to Audi/VW Part number G 052 512 A2.
#3343376 - 04/15/14 10:52 AM Re: VW Passat- Amsoil does not make a gear lube [Re: smokey422]
riggaz Offline
Loc: England
What engine code is yours?
I'll should be able to get you the correct specs
#3343383 - 04/15/14 10:59 AM Re: VW Passat- Amsoil does not make a gear lube [Re: smokey422]
glxpassat Offline
Loc: Huntsville, AL
I've tried RL MT90, RP maxgear, Motul 300v and Motul Motylgear 10w-40 GL-4 in my '03 passat. The motylgear is the smoothest and seems to work just was well as stock in cold weather. The RL gave me a pretty crunchy 1-2 shift. The RP was smooth but was no good below 50F. 10w-40 is the same viscosity as 75w-90, but it can be used as motor oil as well as gear oil whereas the 75w-90 can not be used in a motor.
#3344239 - 04/16/14 07:58 AM Re: VW Passat- Amsoil does not make a gear lube [Re: smokey422]
UG_Passat Offline
Loc: NJ
VW requires either G060 or G070.... I've lost track of the VW specs for gear lubes).
If the 2014 1.8T still uses the 02J tranny.... I've had good experience using Amsoil's MTG on my old 02 Golf TDI with the 02J tranny. It's a 75W90 GL-4 oil.
#3345233 - 04/17/14 04:09 AM Re: VW Passat- Amsoil does not make a gear lube [Re: smokey422]
riggaz Offline
Loc: England
I think grains got it right, on the VW parts system there are only two oils listed for the 5 speed manual
>> 03 11 3 - G052512a2 which is a 75W GL4 - Febi part number 21829
04 11 3 >> - G052527a2 which I can't find data on at the mo
Looks like it depends on your chassis number as to which one is suitable
#3345340 - 04/17/14 08:14 AM Re: VW Passat- Amsoil does not make a gear lube [Re: smokey422]
Hit Offline
Loc: Malta
Hi Smokey
If have access for Liqui Moly is very good oil, its the 4th year voted the best oil from 3 different magazine in Germany. Its a German made and I use it for both my 2 cars, I have Seat Leon FR TDI 2.0L 220hp remapped and eliminated the dpf filter because in my country it gets blocked, its a VW group they have the same engines, transmission and chassis. Liqui moly they have what ever you need, engine, transmission, brake fluid oils and very good additives that really works especially the engine and transmission ones. The other car is a Honda integra type r turbo 500hp on pump fuel. I've used everything I mentioned above and I do everything myself.
Here an example what me and my friends experienced. Do ever imagine a Honda integra turbo at 38psi average of 800hp with c16 fuel, at the 1/4mile engine raving @ 9000rpm, after a boost cut broke the oil pump and we didn't notes and raved it again up to 6000rpm and we knew that some thing happened, because the vtec wasn't working. Then after about 5 minutes or more, we were trying to figuring out the that was come from the timing belt side. Then we took a look at the oil pressure gauge and saw the pressure on "0", and said the engine is ruined.
Then we went the garage and dismantled the engine and fund the oil pump in pieces then
after we saw the crank, main bearing and rod bearing we were speechless, nothing happened all the bearing were like new, YOU wont believe it!! before I didn't believe such a product like this existed. Product called (Ceratec)of Liqui moly. If any body thus not belive all I can say send me an email address to post you few pictures. Than if you still don't believe, I don't know what to say!!
Regards
Ivan
#3345350 - 04/17/14 08:27 AM Re: VW Passat- Amsoil does not make a gear lube [Re: smokey422]
badtlc Offline
Loc: KC
Why can't you use Amsoil's synchromesh fluid? It is just a bit thicker but would work just fine.
2007 Ford Escape XLS 2.3L ATX, Trop Artic 5W30, Fram OCOD, 140k+
2015 Chrysler T&C, 45k+
#3361783 - 05/04/14 07:44 PM Re: VW Passat- Amsoil does not make a gear lube [Re: badtlc]
Wheel366 Offline
Loc: NJ
I used Redline MT-90 in my A4 and it was horrible in the winter. I was going to do Amsoil but figured if that didn't work out I didn't want to switch again so I just used OEM fluid and it is a night and day difference. With the redline I couldn't shift into 2nd if the temps dropped to 20 or lower until the fluid warmed up without a fight. Now, no problems. I use Amsoil in the diffs and engine with no problems.
#3362427 - 05/05/14 01:24 PM Re: VW Passat- Amsoil does not make a gear lube [Re: Wheel366]
badtlc Offline
Loc: KC
Redline MTL would have been the appropriate fluid, not MT90.
#3362455 - 05/05/14 01:56 PM Re: VW Passat- Amsoil does not make a gear lube [Re: badtlc]
glxpassat Offline
Loc: Huntsville, AL
Not if the motor sits longitudinal and uses a spiral bevel gear in the transmission.
#3362476 - 05/05/14 02:14 PM Re: VW Passat- Amsoil does not make a gear lube [Re: glxpassat]
badtlc Offline
Loc: KC
Audi/VW use very thin OEM MTF. Usually under 7 cSt at 100C. Redline MTL is much closer to that than MT90.
#3362481 - 05/05/14 02:18 PM Re: VW Passat- Amsoil does not make a gear lube [Re: smokey422]
glxpassat Offline
Loc: Huntsville, AL
My '03 passat requires a 75w-90, around 14 cst. MTL is a 70w-80. The engines that sit transverse do use the thin gear oil in the tranny.
Edited by glxpassat (05/05/14 02:20 PM)
#3362516 - 05/05/14 02:51 PM Re: VW Passat- Amsoil does not make a gear lube [Re: glxpassat]
badtlc Offline
Loc: KC
They spec 75w-90. They do not use 75W-90. This has been gone over thousands of times. Check the UOA/VOAS of the VW/Audi fluids. They are nowhere near 75W-90.
Fuchs 75W FE is rebottled as the OEM fluid unless something has changed again.
#3362552 - 05/05/14 03:24 PM Re: VW Passat- Amsoil does not make a gear lube [Re: smokey422]
glxpassat Offline
Loc: Huntsville, AL
I had a voa done of the G052-911 which is correct for my car that I bought at the dealer and it was 14.5 cst. There are quite a few different VW G052-XXX fluids.
My VOA
Edited by glxpassat (05/05/14 03:37 PM)
#3362579 - 05/05/14 03:44 PM Re: VW Passat- Amsoil does not make a gear lube [Re: smokey422]
glxpassat Offline
Loc: Huntsville, AL
Volkswagen Gear Oil Specifications - http://www.oilspecifications.org/volkswagen.php
VW G 052 911
Audi specification for transmissions used with longitudinal engine configurations. Products meeting this specification are of SAE 75W90 viscosity and also meet API GL-5 criteria.
#3363140 - 05/06/14 08:18 AM Re: VW Passat- Amsoil does not make a gear lube [Re: glxpassat]
badtlc Offline
Loc: KC
VW G 052 911
Look up the fluids that meet that spec:
http://www.fuchs-europe.com/products/lubricants-motors-machinery/gear-oils/gear-oils-passenger0.html
http://www.eurol.com/en/37-products/3129-eurol-mtf-75w-80-gl5.html
http://news.blauparts.com/20140505-prerelease-vw-gearbox-oil-g-052-911-a2
As you can see, VW/Audi will say 75W-90 in the user manual and other places but their actual performance specs for the fluids are much thinner. This seems to be typical for all modern VW/Audis out there. Thicker fluids from all the major euro fluid makers (75W90) do not meet the VW spec.
Edited by badtlc (05/06/14 08:19 AM)
#3363341 - 05/06/14 12:24 PM Re: VW Passat- Amsoil does not make a gear lube [Re: smokey422]
DuckRyder Offline
Loc: Atlanta
We have a 2014 VW Passat that I love with the 5 speed manual shift and although Amsoil makes an approved motor oil, they don't have an approved gear lube. ....
As a point of order.
Amsoil may make an oil they "recommend" for it or say is "suitable", however there is no Amsoil product listed on the Official VAG Approved Engine Oils .
I would encourage one to understand the distinction.
Robert
  • 2007 Toyota Prius Touring
  • 2005 Honda Civic Sedan
  • 1972 Ford F100
  • 2012 Volkswagen Jetta TDi
#3363369 - 05/06/14 12:57 PM Re: VW Passat- Amsoil does not make a gear lube [Re: DuckRyder]
OVERKILL Offline
Loc: Ontario, Canada
Just an FYI but AMSOIL has actually started to pursue the official Euro approvals. Their mid-SAPS product, AFL for example, sports the following OEM approvals:
BMW Longlife-04
MB-Approval 229.51
Porsche A40
I would expect an official VW approval to be coming up, though as noted, it does not carry one currently. smile
02 Expedition
06 Charger R/T
14 Charger SRT-8
#3363548 - 05/06/14 04:11 PM Re: VW Passat- Amsoil does not make a gear lube [Re: OVERKILL]
DuckRyder Offline
Loc: Atlanta
BMW Longlife-04
MB-Approval 229.51
Porsche A40
I actually consider that good news... Looking forward to the update...
Robert
  • 1972 Ford F100
#3363619 - 05/06/14 05:21 PM Re: VW Passat- Amsoil does not make a gear lube [Re: badtlc]
glxpassat Offline
Loc: Huntsville, AL
"Recommendations" and "suitable for" is not the same as meeting spec or having VW approval. You have to believe their claim that it will work. Good luck with that if your tranny dies under warranty.
All I know is my voa of VW fluid shows the fluid is thick. The Ravenol does not meet GL-5 so I don't know how they can make the claim of meeting spec.
Edited by glxpassat (05/06/14 05:23 PM)
#3366327 - 05/09/14 08:05 AM Re: VW Passat- Amsoil does not make a gear lube [Re: smokey422]
gregoron Offline
Loc: Hawaii
I'd just stick with the factory recommended VAG manual transmission fluid. I wouldn't call it gear lube as that's for a different application. I've tried RL MT90 on my 2000 Jetta and I liked the OEM MTF better. I'll be switching to it next year.
2014 VW Jetta GLI, 6MT, 16k miles.
M1 0W-40, 8k mile OCI
1995 MB E320, 4AT, 221k miles.
M1 0W-40 (next OCI)
#3373304 - 05/16/14 01:28 PM Re: VW Passat- Amsoil does not make a gear lube [Re: smokey422]
benjy Offline
Loc: pa
i use Amsoil oils but Redline gear lubes. put MT-90 in my O2J VW 5 speed, it helped shifting a lot. it took about a thousand miles though, wonder why. put it in mt TT's O2M i believe 6 spd manual as well
#3376294 - 05/20/14 09:21 AM Re: VW Passat- Amsoil does not make a gear lube [Re: badtlc]
simple_simon Offline
Loc: Indianapolis, IN
Then RP Synchromax should be the choice. Same as BMWs. Much better than anything offered by Redline or Amsoil in that category.
#3412891 - 07/02/14 08:11 PM Re: VW Passat- Amsoil does not make a gear lube [Re: smokey422]
benjy Offline
Loc: pa
many years ago in my 01 jetta O2J 5 speed i had run Amsoil series 2000 in my gearbox-transaxle, after several thousand miles shifting deteriorated, switched to MT-90 + forever happy. using it in my 01 TT 6 speed now, more satisfaction again. i do use Amsoil's REAL synthetic oils though
Edited by benjy (07/02/14 08:12 PM)
Page 1 of 2 1 2 >
