JHZR2
Staff member
As many know, I have a 1998 Chevy pick up truck that doesn't get a lot of use. It has gone through two batteries in recent memory and so there may be a very slight short-circuit someplace. Regardless the alternator voltages are very good and put out strong enough to always keep the battery charged so it can go for a long time just sitting. Operationally everything is fine. However I was working on it the other day and have noticed then as well as when I have operated the last few times, that the headlight brightness seems to fluctuate a little bit when it's sitting at idle. Before when operating it I thought I noticed this but couldn't really confirm. When I was working on it recently the headlights were beaming directly against a dark garage door and it was very obvious.
In addition when I was working tonight I could also tell if there was a slight fluctuation in the brightness in the gauge cluster. I certainly had never noticed that before.
I know that during operation the voltage is very steady. Oddly I took a voltage reading from both the accessory 12 V plug as well as a reading on the OBD II port. These values are not the same but I'm not sure if it's due to calibration or some other issue.
I would imagine that the auto parts stores have an alternator test rig that I could use. That said I really don't trust that considering that two weeks ago my parents had alternated I was failing and the store tested it as good. So what should I look for I assume I should search for AC ripple characteristics on the alternator output. Of course I can check the battery both load and impedance characteristics, but I'm not sure that that's going to do me much good. If the battery impedances to high simply won't charge without a huge overvoltage, I just won't take very much current which means that the alternator should actually be working less. Of course if it's dumping into a short circuit that would be an issue I do have a DCM clamp but because I don't have a baseline reading I don't know if I can make heads or tails out of it.
Any ideas what typically causes headlight brightness fluctuation? Suggestions on what tests I should run?
Thanks!
Thanks!
