Originally Posted By: fdcg27
We'll have to agree to disagree as well.
If varnish is the precursor to sludge (it isn't) then this 163K mile engine should already have sludge in the upper cylinder head.
It doesn't.
Sludge doesn't form without varnish
That is to say that while varnish doesn't always necessarily lead to sludge, sludge always has varnish happen before it.
Also, depending on engine design it may have some sludge in the pan area. Different engines "go to [censored] in a hand basket" in different ways
A prime example, a Ford Windsor will show some moderate varnish on the heads but the lifter valley can be chock full of sludge. I've seen a 3.8L GM with nothing in the heads but some varnish and about an inch of the "good stuff" in the bottom of the pan
Thought this PDF explained it well (they are a member of the STLE BTW):
http://www.focuslab.co.th/pdf/vspi_en.pdf
Quote:
What is varnish?
- Varnish is a soft contaminant composed of
lubricant degradation by-products that are less
than 1 micron in size and is not measured by
traditional particle count.
- Varnish deposit is a thin-orange, brown or
black insoluble film deposit occurring on
internal of lubricant systems .
- Varnish is a high molecular weight substance
that is unstable in oil.
- Varnish deposit is unable to remove by
mechanical filtration
Quote:
What is sludge?
- Sludge is varnish which have higher water
content
- Sludge looks like a soft mud-like deposit that
settles out of the oil
- Sludge is also a soft contaminant .
- Sludge contaminant , if prolonged elevated
temperatures will evaporate the moisture from
the sludge contaminant.
Essentially sludge IS varnish. Varnish that has managed to get that much worse. And that product, as noted in the last section of the 2nd excerpt can dry up and give us that lovely baked on sludge that you can chip off with a screwdriver, LOL!!!!
