In the last 5 hours of operation, I've had two new B&S OEM low tone mufflers fall apart. Basically the weld? fails where the outer housing is connected to the pipe coming out of the engine. I end up with that whole housing falling off, and just a perforated straight pipe sticking out of my engine. I'm perfectly OK with having my Briggs 8hp I/C flat head straight piped, but my neighbors and wife are going to disagree.
Two of the same failures in five hours tells me I've done something wrong. After the first failed, I was certain to only use the "pipe" portion to screw the muffler into the engine block. So the outer portion hasn't been stressed from wrenching on it.
What I have noticed is that both mufflers seem to keep working loose. I crank on the tightening ring as much as I can, but it always seems to back off.
So what's going on? I can't imagine I have two defective mufflers from two different suppliers. Both were OEM B&S
Pic attached for clarity on the issue. Red = failure point.
