Starting earlier this week, I began to notice occasional unusual, and unlikely coolant temp readings via my ScangaugeII. For example, I'd drive the truck around a while, and it would read between about 170*F and 185*F on a warm day (70*F+), and be bouncing all over the place. It's not a stuck open t-stat, since it does sometimes read correctly and show the t-stat opening. I really caught it the other morning when it jumped from 160*F to 190*F in one refresh of the SGII (2 second refresh rate). It had been running for 20 minutes, so I knew 160*F was [censored]. Busted. I'm thinking that sort of behavior can only be the coolant temp sender. Planning on replacing it tomorrow with a Motorcraft. The original made it 12 years and 151K miles, so I'll go with it again.
Of course, this whole time, the temp gauge was sitting right in the middle. A supposedly 30*F change in temp over 2 seconds = dead middle, everything is normal on the gauge! How informative! 160*F-210*F = middle. No CEL because it reads within a believable range for the computer. Runs fine, but is probably hurting my fuel economy. I would have no idea if it wasn't for the Scangauge.
I am happy with the life of the part, I just wish Fords didn't try to hide problems like some wounded animal that doesn't want to show weakness. Thankfully the SGII doesn't lie.
