I am in need of some advice about what type and viscosity lubricant to use in my French 1982 vintage lathe gear box. The owners manual States the following.
2.5 degrees Engler at 50 degrees centigrade hydraulic oil.
Let me tell you about the gear box. Typical straight cut gears however the gear box contains wet clutches and yellow metals. Any help would be great.
Shell, Mobil, and Amsoil tech support were little to no help.
