Originally Posted By: ram_man
I am missing the point....is there a logical reason to perform this test that I am not understanding? The filter doesnt serve as valuable a purpose as the oil. Also oil is a filter. Why not change it out once in awhile? A filter at 3,000 probably looks very goodd inside still. Imo you would be better off changing oil more often and leaving the filter. Oil is to cheap for me not to do it every 5,000 miles or so. Ive been given [censored] on here before but my opinion is no engine has ever been damaged from changing the oil to soon on the other hand pushing oils limits has proven risky in certain cases, pop the valve cover off and let us see that. Then we can compare your pictures to mine and people with a similar mind set as me and see who's is cleaner.
Remember I get about 1 1/2 quarts of fresh oil every 4k, so essentially it's a full change every 12k. So it's not like I have the same old oil forever and ever.
My point is to save oil. If I were changing oil at 4k like before, that would have been 16.5 gallons of oil use total. I estimate for the same mileage using my system I have used 5.5 gallons. Then there's the issue of ease of the change. I just pull the filter, so that means no jacking up the car, I just reach under there and unscrew the filter. The waste oil can be caught in a paper cup. The whole process takes two minutes. I can do it on the road on long trips no problem. I can't remember the last time I actually had to dispose of the waste oil, maybe when I changed my Dad's transmission fluid. Then there's the cost. I buy the $3.29 filters at Wal Mart. So the total oil used, plus the filter cost me about $7 vs. about $19 before.
