F-106 Fumoto Valve
by DBMaster
08/29/16 05:43 PM
Propane/Oxygen vs Oxygen/acetylene
by Vern_in_IL
08/29/16 05:33 PM
CarQuest Red 85372 Cut open
by blupupher
08/29/16 05:30 PM
Battery dead on new car
by Leo99
08/29/16 05:22 PM
1997 Saturn P0326 No power
by nwjones18
08/29/16 04:29 PM
Can I use lower weight ?
by ST2008
08/29/16 04:25 PM
Amsoil 0W-30 Honda S2000 40,259 OCI w/bypass
by slalom44
08/29/16 03:32 PM
Holdup
by Whitewolf
08/29/16 03:14 PM
boosting diesel perf using propane/CNG/meth added
by columnshift
08/29/16 03:04 PM
HP for '96 Toyota Corolla?
by Benzadmiral
08/29/16 03:04 PM
Gene Wilder Dies at 83
by John_Conrad
08/29/16 02:52 PM
Simple oil question, Honda GCV 160
by Popsy
08/29/16 02:49 PM
LazLong, gioburk, turrican, GGilbert, leje0306
58952 Registered Users
79 registered (4WD, AnthemBassMan, Bandito440, AlaskaMike, Astro_Guy, asiancivicmaniac, 10 invisible), 1629 Guests and 7 Spiders online.
58952 Members
66 Forums
253739 Topics
#3338643 - 04/10/14 10:51 AM Toyota Camry 12-13 HVAC Recall **INSTRUCTIONS**
SumpChump Offline
Loc: Upper Midwest by the Lakes USA
Here is a 3MB scan of the actual recall instructions to the dealer on the procedure to fix the dreaded HVAC recall for the 12-13 Toyota Camry in which the HVAC evaporator condensation collects in the unit due to a plugged drain and then shorts out the aiorbag module. The only "catch" with this document is it is black and white and one diagram shows "to remove the red items" for access. Well, you can image which of the items in the parts blowup diagram really would need to be removed.
THis gives you an ide of the amount of console tearing apart they will have to do. And then you get to enjoy all the scratches, unsticky sticky tapes and creaking plastic parts that they have re assembled.
Link to PDF of ACTUAL TOYOTA DOCUMENTS:
CAMRY RECALL HVAC INSTRUCTIONS 12-13
#3338688 - 04/10/14 11:42 AM Re: Toyota Camry 12-13 HVAC Recall **INSTRUCTIONS** [Re: SumpChump]
SatinSilver Offline
Loc: Ohio
My dad had this done to his 2012 Camry about a month ago. The dealer automatically scheduled to have the work done when he scheduled his oil change for the 40k service. The only major downside was that it took some time out of his day but luckily he's retired. He was at the dealer from 1pm to 3pm or so. But at least it's done and over with. thumbsup
This has been the only issue with the car which was purchased in October of 2011. This car replaced a 2007 Camry that was also an early production model built in Oct of 2006.
2012 Toyota Camry 62k miles- PP 0w20, oem filter (TGMO all prior)
2005 Toyota Matrix 103k miles- MC 0w20 syn-blend, MC 822 filter
