adhesive for pea gravel?
by xfactor9
05/24/16 08:19 PM
Micro guard Gl14609 150 hours
by robo339
05/24/16 08:02 PM
walking thru a Harbor Freight is better than sex
by turtlevette
05/24/16 07:58 PM
'14 Durango 3.6L, PUP 5w20, 7.5k, TBN/TAN
by Mantooth
05/24/16 06:59 PM
Advice: Odyssey or Sienna?
by Barwich
05/24/16 06:43 PM
Any HR specialists out there?
by bustednutz
05/24/16 06:23 PM
Jawa 350/360 (two-stroke) motor oil
by volodymyr
05/24/16 05:52 PM
Red Line 20W60 Synth. 1k Miles '13 KTM DUKE 690
by albertdi
05/24/16 05:49 PM
Tire Suggestions - 2014 Dodge Grand Caravan
by Nick1994
05/24/16 05:38 PM
Completing your 80% lower receiver manually
by Merkava_4
05/24/16 05:18 PM
5.4 3V VCT solenoid replacement
by 04SE
05/24/16 05:11 PM
Changed the spark plugs on Sunday, and [censored]??
by SirTanon
05/24/16 04:46 PM
Hokie_Dave, ant3a, afterburnerbg, SupraSaiyan, Bighorn2500
57973 Registered Users
119 registered (ABerns, AZjeff, 2004tdigls, 2009Edge, AandPDan, bchannell, 11 invisible), 1782 Guests and 110 Spiders online.
57973 Members
66 Forums
249365 Topics
Page 1 of 2 1 2 >
#3338140 - 04/09/14 08:21 PM Old tires like new what would you do?
JHZR2 Offline
Loc: New Jersey
This is on the wear bar:
The kicker:
So although there a little bit dirty and muddy, the tires (potenza 960re pole position) are like brand-new. They are just a little bit old being that there now seven years. They have over 25,000 miles on them, but the car they're on hasn't done a ton of miles recently.
So this is one of those age versus mileage issues where the tires look good and have a ton of tread but it just past their useful age.
Car is used almost entirely for long highway trips at high speed and with a lot of load in the car.
Next time there's a $70 Michelin rebate would be prudent to replace them??
Often the car is garaged or under a cover, so they don't always necessarily see a ton of uv.
#3338143 - 04/09/14 08:24 PM Re: Old tires like new what would you do? [Re: JHZR2]
Quattro Pete Offline
Loc: Great Lakes
CapriRacer often said that up North, the time limit on tires would be around 10 years, so I'd say you keep using them until then.
'02 530i (Edge HM 10W-40)
'15 Q5 3.0T (Edge 5W-40)
#3338144 - 04/09/14 08:25 PM Re: Old tires like new what would you do? [Re: JHZR2]
Realtech214 Offline
Loc: Florida
Keep them on the car till their too worn down
2015 Silverado Crew Cab 5.3 LT
2001 Suburban LT
- I NEVER THOUGHT I WOULD LIKE OIL SO MUCH -
#3338147 - 04/09/14 08:28 PM Re: Old tires like new what would you do? [Re: JHZR2]
901Memphis Offline
Loc: Northern Kentucky
Look good to me. They say 10 years is the limit and that has to be a conservative.
2002 Buick Century 125k - Built 4T65e(Maxlife) - M1 0w40 /Fram Ultra XG 3387A
1998 Nissan Altima 335k - 5MT - M1 HM 5w30/Fram Ultra XG7317+MOS+ATP 205
#3338148 - 04/09/14 08:29 PM Re: Old tires like new what would you do? [Re: JHZR2]
Jarlaxle Offline
Loc: New England
I'd run them in a second.
1979 Coupe de Ville, 542 stroker, 15W-40 Super Tech, Delco
2011 Crown Vic P71, 5W-20 Valvoline NextGen, Purolator
2012 Suzuki AN400A, 10W-40 ST, Delco
#3338149 - 04/09/14 08:29 PM Re: Old tires like new what would you do? [Re: 901Memphis]
JC1 Offline
Loc: Oshawa, Ontario Canada
Keep using them. I have snow tires from 2004 and they are still fine.
Regards, JC.
#3338154 - 04/09/14 08:31 PM Re: Old tires like new what would you do? [Re: JHZR2]
yonyon Offline
Loc: NJ, USA
There isn't much in the way of visible cracking or any of that. Provided they still ride well I would go for another 2 or 3 years if they don't have to see winter use. If they're used on a car you like to play with or if they have to be used in winter, sell them as good used tires.
#3338168 - 04/09/14 08:37 PM Re: Old tires like new what would you do? [Re: JHZR2]
crazyoildude Offline
Loc: New Jersey
i replaced the tires on my 95 caddy last year or the year before i cant remember exactly and they still looked good im sure the tire dealer sold them to someone. I bought the new ones wholesale so i let him have them
#3338190 - 04/09/14 08:58 PM Re: Old tires like new what would you do? [Re: JHZR2]
Eddie Online   happy
Loc: Florida, Cape Coral
Use them till they have sidewall cracks or the tread is gone.
CX5 Touring 2.5L :-)
#3338203 - 04/09/14 09:14 PM Re: Old tires like new what would you do? [Re: JHZR2]
spasm3 Online   content
Loc: out there
I would use them. The only time i dont fudge with tire age is on travel trailer tires. I change those at 7 years.
13 elantra 46k 5w30 ultra
03 chevy avalanche67k pyb
02 saturnsc1 66k 0w40 castrol
01 saturnsc1 185k being rebuilt
93 ciera 79k 5w30 havo
#3338243 - 04/09/14 10:15 PM Re: Old tires like new what would you do? [Re: JHZR2]
stephen9666 Offline
Loc: USA
Here's what Bridgestone says:
http://www.bridgestonetire.com/customer-care/tire-warranties/full-warranty
Quote:
Tire Service Life
Make sure your tires, including the spare, continue to be
regularly inspected after 5 years of service to determine
if they can continue in service. Regardless of the tire’s
condition or tread depth, it is recommended that tires more
than 10 years old be taken out of service and replaced with
new tires. REMEMBER TO CHECK YOUR FULLSIZE OR TEMPORARY SPARE, ALSO. A spare tire
over 10 years old may look like a new tire, but it should be
replaced. See “Tire Manufacture Date,” the next section in
this manual.
The 10 year period after the date of production is not an
indicator of actual service life for any individual tire. Some
tires will need to be replaced before 10 years due to conditions such as punctures, impact damage, improper inflation,
overloading, tread wear or other conditions involving use
or misuse of the tire. If a tire is worn out or otherwise
unserviceable from damage or conditions of use, it should
be replaced regardless of when it was produced or placed
in service.
The vehicle manufacturer may consider vehicle performance characteristics when making tire replacement recommendations. Consult your vehicle owner’s manual for
any information regarding tire service life and replacement
and follow the recommendations applicable to your vehicle
#3338248 - 04/09/14 10:25 PM Re: Old tires like new what would you do? [Re: JHZR2]
Rolla07 Offline
Loc: MTL, CANADA
Keep using for 2-3 years
2007 Corolla Red Pearl 138k miles
Pennz Ultra 0w40 & Napa Proselect
#3338260 - 04/09/14 10:45 PM Re: Old tires like new what would you do? [Re: JHZR2]
bvance554 Offline
Loc: VA
Keep em!
#3338274 - 04/09/14 11:00 PM Re: Old tires like new what would you do? [Re: JHZR2]
ram_man Offline
Loc: southern mo
If the rubber passes my feel test and visual test I would run them.
2015 dodge dart se rallye package
1995 Dodge ram 1500 5.9l
2003 chrysler pt cruiser
#3338277 - 04/09/14 11:03 PM Re: Old tires like new what would you do? [Re: JHZR2]
KitaCam Offline
Loc: SunnySouthFlorida
The penny test has been replaced by the quarter test.
Kitacam is an 05 Camry LE/I4/MT; 3/16 @ 137,000....MaxLife Syn Blend 5w-30...with P1 filter
Page 1 of 2 1 2 >
