What can I do to reduce my Mondeos oil consumption habit?
It’s a 2005 model with the Duratec 1.8 petrol engine and I use 5W-30 as per the Ford handbook, unfortunately the valve stem seals and oil control rings in these cars have a reputation for being made out of cheese.
It occasionally smokes briefly on start-up, as well as under high RPM load.
It goes through between 250/500ml of oil every 300 miles (which is every week), as a consequence the bonnet is open frequently...even more so after a spirited drive.
The car is just a snotter and not worth more than shed money, so I am willing to experiment a little. I was thinking maybe I could switch to 5W-40, or try an oil additive that claims to free stuck piston rings?
