Years ago we used to hear of break in oil. That term and even the oil seem to have disappeared for years but now it seem to have reappeared. I do think some mfrs that recommend a synthetic oil currently use a break in oil to promote better wear in between parts. Could be a blend of sort???
My question is a friend of mind bought a new John Deere tractor. The manual says it has break in oil and should continue to run this B I O for 500 hrs. He has slightly less than 100 hrs on his tractor. Upon calling his dealer they sent a truck out for a service call. The mechanic either didn't have or didn't put the same B I O back in. He (mechanic) changed it over to the recommended oil for over 500 hrs. My friend is worried that will cause problems! Got any thoughts.
