adhesive for pea gravel?
by xfactor9
05/24/16 08:19 PM
Micro guard Gl14609 150 hours
by robo339
05/24/16 08:02 PM
walking thru a Harbor Freight is better than sex
by turtlevette
05/24/16 07:58 PM
'14 Durango 3.6L, PUP 5w20, 7.5k, TBN/TAN
by Mantooth
05/24/16 06:59 PM
Advice: Odyssey or Sienna?
by Barwich
05/24/16 06:43 PM
Any HR specialists out there?
by bustednutz
05/24/16 06:23 PM
Jawa 350/360 (two-stroke) motor oil
by volodymyr
05/24/16 05:52 PM
Red Line 20W60 Synth. 1k Miles '13 KTM DUKE 690
by albertdi
05/24/16 05:49 PM
Tire Suggestions - 2014 Dodge Grand Caravan
by Nick1994
05/24/16 05:38 PM
Completing your 80% lower receiver manually
by Merkava_4
05/24/16 05:18 PM
5.4 3V VCT solenoid replacement
by 04SE
05/24/16 05:11 PM
Changed the spark plugs on Sunday, and [censored]??
by SirTanon
05/24/16 04:46 PM
Hokie_Dave, ant3a, afterburnerbg, SupraSaiyan, Bighorn2500
57973 Registered Users
119 registered (ABerns, AZjeff, 2004tdigls, 2009Edge, AandPDan, bchannell, 11 invisible), 1782 Guests and 110 Spiders online.
57973 Members
66 Forums
249365 Topics
Page 1 of 3 1 2 3 >
#3336750 - 04/08/14 11:10 AM Oil for my di engine
waltywalt Offline
Loc: ny
What 5w30 syn oil has the best noack numbers and also I was looking for an oil that doesn't shear down so much. It seems like most of the 5w30 oils shear down to a 5w20 a lot in di engines. I usually use qsud or Castrol syntec.
#3336759 - 04/08/14 11:21 AM Re: Oil for my di engine [Re: waltywalt]
Eddie Online   happy
Loc: Florida, Cape Coral
I ran PP 5w30 in my Turo DI mazda CX7 and have good UOAs using 6,000 mile oil change intervals. My oil did not shear down over the 6K miles. Ed
CX5 Touring 2.5L :-)
#3336774 - 04/08/14 11:34 AM Re: Oil for my di engine [Re: waltywalt]
waltywalt Offline
Loc: ny
Thanks ed
#3336775 - 04/08/14 11:35 AM Re: Oil for my di engine [Re: waltywalt]
waltywalt Offline
Loc: ny
Ive used pp also but isn't it on the lighter side of the 5w30s.
#3336779 - 04/08/14 11:37 AM Re: Oil for my di engine [Re: waltywalt]
Quattro Pete Offline
Loc: Great Lakes
The reason is that most of these readily available 5w-30 oils are energy conserving, which means they are formulated on the lower end of the 30-grade range of viscosity. And so it doesn't take much for it to drop into the 20-grade territory.
If you start with an oil that's formulated as a heavy 30-grade, then you're less likely to shear so much that it'll drop to a 20-grade. Unfortunately, such oils are not energy conserving. Example of such oil with very low Noack: Mobil1 ESP 5w-30.
'02 530i (Edge HM 10W-40)
'15 Q5 3.0T (Edge 5W-40)
#3336783 - 04/08/14 11:39 AM Re: Oil for my di engine [Re: waltywalt]
waltywalt Offline
Loc: ny
Mobil 1 esp is that the 15,000 mile oil
#3336785 - 04/08/14 11:41 AM Re: Oil for my di engine [Re: waltywalt]
Loc: Great Lakes
No. You're thinking of M1 EP.
#3336810 - 04/08/14 12:12 PM Re: Oil for my di engine [Re: waltywalt]
dave1251 Offline
Loc: Maricopa, AZ
I have a question. Why are you so concerned about shearing?
don't use.
#3336814 - 04/08/14 12:17 PM Re: Oil for my di engine [Re: waltywalt]
waltywalt Offline
Loc: ny
Because I wanted to use a 5w30 and not a 5w20 to begin with. If I wanted to use a 20w I would of just started with it in the first place. Just personal preference I guess.
#3336816 - 04/08/14 12:19 PM Re: Oil for my di engine [Re: waltywalt]
waltywalt Offline
Loc: ny
I have never got a uoa on the oil in this car but ive read on hear a lot about 5w30 oil shearing down to a 20w in a lot of di engines. I would guess its because of the fuel washing down but idk for sure.
#3336823 - 04/08/14 12:38 PM Re: Oil for my di engine [Re: waltywalt]
Loc: Great Lakes
I think Dave's point was that it may not necessarily matter that your oil thinned to a 20-grade. Engine manufacturers are well aware of the potential fuel dilution, and specify oil grades accordingly.
Now, if you started with a 20-grade and it ended up thinning to a 10-grade, then that could have been a problem.
#3336824 - 04/08/14 12:39 PM Re: Oil for my di engine [Re: waltywalt]
dave1251 Offline
Loc: Maricopa, AZ
OK. Does your manufacture recommend a 5W30? If so do you believe the engineers that have made this recommendation have factored in that a 5W30 will shear? If so testing was done on this engine design that it would be nearly impossible for you to replicate in everyday driving use and a 5W30 is robust enough to protect your engine for it's designed lifetime shearing and all.
don't use.
#3336874 - 04/08/14 01:37 PM Re: Oil for my di engine [Re: dave1251]
TTK Offline
Loc: TN
With top notch thinking like that, we can just shut down all sections of BITOG except UOAs.
2010 Volvo V70-3.2
Current Fill:Mobil 1 AFE 0w-30
2014 Subaru Forester, 0w-20 Castrol Magnatec
2001 Chevrolet Prism
NAPA Synthetic 5w-30
#3336908 - 04/08/14 02:41 PM Re: Oil for my di engine [Re: TTK]
dave1251 Offline
Loc: Maricopa, AZ
Oh really? Do you have purpose for posting this? Because your comment is very vague and it can be misinterpreted/interpreted into many directions.
Please explain.
don't use.
#3336933 - 04/08/14 03:13 PM Re: Oil for my di engine [Re: waltywalt]
A_Harman Offline
Loc: Michigan
What 5w30 syn oil has the best noack numbers and doesn't shear down so much.
Are you willing to go to boutique oils, or want to stick with readily available synthetics?
AMSoil HDD has 9% NOACK, and is very shear resistant. It's a diesel oil formulated for pre-2007 engines, so it's probably high SAPS.
RedLine 5w30 has 6% NOACK, and is very shear resistant. It is formulated for gasoline engines.
1985 Z51 Corvette track car
2002 Camaro Z28 LS1/6-speed
2001 Dodge Ram 2500 diesel
1972 GMC 1500 shortbed project truck
Page 1 of 3 1 2 3 >
