Ok guys/gals, I will probably need to put on my flame suit for this.
My new to me 2002 White Chevy Silverado has the typical peeling of clear on the hood and roof. The rest of the paint is in great shape. My original plan was to do the Rustoleum roll on job on the hood and roof to protect it and maybe match somewhat well.
BUT, the whole reason I was going to do that was due to money restriction and I don’t have access to a big enough compressor. After further thought, this might not be my best option with a newborn at the house and considering the time that it would take to color sand. I don’t plan on attempting this until this summer so she will be a tad older, but still.
The new Turbine Paint System from Eastwood has peaked my interest:
Eastwood Turbine Paint System
That, coupled with the GM White Single Stage Acrylic Enamel from TCP would provide a very cheap alternative all things considered. And considering how well I could get the turbine to spray, minimal color sanding.
Current plan is to use my DA to sand down to primer, then depending on how the factory primer looks, either spray primer, or go straight to the single stage.
Any thoughts or reasons why my current plan won’t work? The Eastwood system is an easy sell to the wife too, since it can be used around the house as well.
Any and all opinions are appreciated.
Thanks!
Thanks!
