CapriRacer points out my Camry's preferences...
The Camry is obviously a "touring" car, NOT a sports/performance ride..
My experience...
The Camry's door jamb spec is 29psi for the 15s that came on it...for comfort riding on OEM type tires....I had run 35 on them (51psi was max cold psi) and got even wear and better performance (for OEM tires)...and then...
When I upsized to 17" wheels and high performance tires that also had a max 51psi, I tried various PSIs and determined that 45psi was best....based on the "contact patch" showing dirt on the tread from shoulder to shoulder on the front, and a bit less on the shoulder on the rear...
I had run tests on those tires at 3psi increments over 30psi watching the tread contact patch for wear, but more importantly, testing results while running/braking/turning hard, testing on dry and wet pavement for lean, slipping, and directional stability, including "panic stops" (testing the ABS, as this is my first car with ABS), and relatively fast starts at stop lights/signs where oil drops collect to encourage slipping, to get a feel for how much I can "push" the Camry's daily driver characteristics, before settling on 45psi...
With a stick, there's a lot more to test as I'm responsible for controlling the engine's RPMs...
