We have a 13 horse pressure washer with an electric start. The battery normally only lasts 2 months or so after being installed before being completly drained. What could be causing this? I suppose I could disconnect the battery after each use, but its a huge hassle. I wouldnt mind pull starting it each time either, but a charged battery is needed to run the water heater.
And dont worry, I just changed the oil. Factory fill out, M1 10w30 in. Its what Dad wanted.. I personally wanted to try T5 or T6.
