Originally Posted By: virginoil
In short part of the GC hype commenced around a member of BITOG claiming the level of the oil his dipstick never moved after he started using GC made in Belgium, this later proved to be inaccurate.
Sir, the issue I have is not about BC vs GC, per se. What I am saying is that your anecdotal statement, quoted above, is non-sensical. To paraphrase from your original mention of this, you said "the oil level never changed on the dipstick over the course of the OCI. But then this person drained the oil and found that less drained out than he had original put in."
So this person concluded that BC was bad because his motor lost oil when using it. What does "lost" mean in this context? Burned it? Leaked it? Evaporated it?
Please enlighten me;
1) Why would the dipstick's oil level measurement never change if the oil level had indeed dropped from a properly measured fresh fill? This scenario makes no sense what-so-ever.
Perhaps this person was the guy on E46Fanatics who recently asked if he should check his oil level - via dipstick - with the engine running or turned off. I won't explain further except to say that all E46s are wet sumps.
2) If the oil level hadn't changed on the dipstick, why would anyone drain their oil and measure how much came out?
What this suggests to me is that this person measured the oil at drain time so they could determine how much oil was required for the refill. Basically, they didn't know their vehicles capacities.
In summary, even though I've used GC 0W-30 and now use BC 0W-30, that's not to say that I think Mobil 1 or Pennzoil Platinum are inferior oils. In my opinion, ALL BRAND NAME oils are so good I don't think it truly matters what brand oil you use, so long as it meets the specs required for your particular application.
It's analogous to why I like to drink my particular brand of beer or label of wine. Are my choices really any "better" than the brands and labels that other people drink? No. My choices are made simply because I have a brand/label preference. It's all good.
GC/BC has many satisfied users. So does Mobil 1, Pennzoil, etc. To say that GC/BC was, or has become, a bad oil based on your anecdotal comments about a dipstick level not changing is not a compelling argument on you part.
You wouldn't happen to have a link to that thread, do you?
Scott
