Question about grease for exmark mower
by Jetstreamz06
12 minutes 13 seconds ago
Grease on door seals and glass
by JHZR2
26 minutes 57 seconds ago
15k miles on Fram xg6607 2011 Mazda 2
by micmac
45 minutes 55 seconds ago
2001 Mazda Tribute atf
by urrlord
56 minutes 1 second ago
Bought a 21..95 Lawnmower battery at O'Reiily's
by andyd
Today at 09:20 PM
How do you feel about castrol edge 0w30 for a z06
by Jetstreamz06
Today at 08:33 PM
04 Mercedes c230 any good
by barkingspider
Today at 08:29 PM
Best spark plugs?
by jk_636
Today at 08:13 PM
Recoil, .380 versus .32?
by bobbob
Today at 07:47 PM
Winter + Slightly off concentration of glycol
by nobb
Today at 07:31 PM
Good synthetic oil for ford transit ecoboost?
by Jetstreamz06
Today at 07:26 PM
Reuse fram XG for 1 more O/C?
by gabriel9766
Today at 07:21 PM
stydel311, jackadf, rlb4, apenland01, 2ManyMiles
57767 Registered Users
85 registered (2015_PSD, 74DartSport, 06AllAmerican, 2KBMW, B320i, 11 invisible), 1317 Guests and 318 Spiders online.
57767 Members
66 Forums
248335 Topics
#3334780 - 04/06/14 08:41 AM PT cruiser battery replacement help ASAP
Tuffy1760 Offline
Loc: upstate NY mohawk valley
2001 pt cruiser... Got airbox off battery terms unhooked... battery not coming out... some type of tricky tie down deal?? cannot see anything... In driveway right now... thanks...
2000 F-150 Harley edition- this is for fun !
2008 Chevy Aveo5- real world car
Royal Purple fan
#3334784 - 04/06/14 08:45 AM Re: PT cruiser battery replacement help ASAP [Re: Tuffy1760]
eljefino Offline
Loc: ME
Pictures? I thought you had to go in thru the fender liner for those.
#3334788 - 04/06/14 08:48 AM Re: PT cruiser battery replacement help ASAP [Re: Tuffy1760]
javacontour Offline
Loc: Illinois
Should be just one block with a 1/2" bolt holding the battery in place. Is there a insulating "blanket" around the battery? If so, perhaps it's blocking your view of this bolt.
network down, IP packets delivered via UPS -BOFH
#3334804 - 04/06/14 09:14 AM Re: PT cruiser battery replacement help ASAP [Re: javacontour]
tomcat27 Online   content
Loc: Midwest
2015 Rogue, 2014 Sentra, 2001 Camry, 2005 Starcraft, 1998 Dodge B1500
1996 Sebring Jx, 1995 Jeep ZJ, 1970 Cougar, 2010 Vstar, 1989 Radian
#3334839 - 04/06/14 09:53 AM Re: PT cruiser battery replacement help ASAP [Re: Tuffy1760]
Warstud Offline
Loc: MIchigan
Gotta remove the entire air filter box to get to the battery hold-down. The filter box just pulls out (no bolts).
#3334842 - 04/06/14 09:55 AM Re: PT cruiser battery replacement help ASAP [Re: Tuffy1760]
slug_bug Offline
Loc: Michigan
Pull out the air cleaner box. It's only held in by two press in type connectors. Once you get the hoses off just pull straight up. Then you can get at battery. There was a nice write up with pictures on a Mopar forum. I'll post it here if I find it. Did this on my old 2003 PT.
2013 Ford Fusion 2.5l (50k)
2010 Lincoln MKX 3.5l (66k)
2007 Dodge Caravan 3.8l (144k)
2003 Merc. Mountaineer 4.6l (87k)
2011 Yamaha Vstar 650 (< 1k)
#3334848 - 04/06/14 09:58 AM Re: PT cruiser battery replacement help ASAP [Re: Tuffy1760]
Tuffy1760 Offline
perfect explanation thanks... done... yanked the airbox out and found the bolt... battery replaced with new, air filter (pur classic), oil change, nextgen high mileage, pure one, done. Considering the rep for work on a PT cruiser, once you guys got me started, I was all set... Might try plugs in the future... calling it a day... getting Corona Light in a few...
THANKS FOR HELP!!!
Royal Purple fan
#3334895 - 04/06/14 11:11 AM Re: PT cruiser battery replacement help ASAP [Re: Tuffy1760]
Rolla07 Offline
Loc: MTL, CANADA
THANKS FOR HELP!!!
Corona light?!?! Isnt Corona light enough?
2007 Corolla Red Pearl 134k miles
TGMO 0w20 & Toyota OEM filter
#3334906 - 04/06/14 11:29 AM Re: PT cruiser battery replacement help ASAP [Re: Warstud]
Spazdog Offline
Loc: Arlington
thumbsup yep.
THANKS FOR HELP!!!
If it's a turbo, you can do the plugs in a couple of minutes in between the intake runners. If it has a plastic intake? I haven't figured out a way to do it without removing the upper intake.
2013 Chevrolet Cruze Eco - dealer Dexos
2014 Chrysler 200S - Whatever the dealer put in it.
1987 Honda CN250 Helix - Penn Platinum Euro5W40
#3334936 - 04/06/14 12:31 PM Re: PT cruiser battery replacement help ASAP [Re: Tuffy1760]
Rick in PA Offline
Loc: Southeastern, PA
I've done the plugs on my '01 Cruiser a few times. It's not a bad job but does involve a bit of rigmarole. In short, a bunch of stuff has to be disconnected from the intake manifold. Then the intake manifold is unbolted and rotated up and held up with a bungee or some wire to the underside of the hood. Then you have access to the plugs, standard spark plug replacement from there on. After replacing the plugs, you lower the manifold, bolt it back in place and reconnect the items disconnected in the first step.
There's some guides on the Internet, I'd look them up.
You may want to replace the plug wires at the same time (I should have done that last time I did my plugs).
Pick a lazy day when you have some time and no pressure of something else that has to be done.
A wise man told me:
"Heat is your friend." and "Any oil is better than no oil."
#3335019 - 04/06/14 02:24 PM Re: PT cruiser battery replacement help ASAP [Re: Tuffy1760]
javacontour Offline
Loc: Illinois
I thought you said you had the air box off in your first post????
#3335159 - 04/06/14 06:04 PM Re: PT cruiser battery replacement help ASAP [Re: Tuffy1760]
Tuffy1760 Offline
Sorry, got the cover for the filter off first... then I yanked the box off... easy...
Royal Purple fan
