Will ATP205 help with a head oil leak
by NattyBoh
07/24/16 09:11 PM
Why is 100% gas more expensive in the city?
by TurboFiat124
07/24/16 09:06 PM
Trouble getting a copper pipe sweat fitting sealed
by NateDN10
07/24/16 08:58 PM
Murphy oil
by TurboFiat124
07/24/16 08:53 PM
I think I'm getting pure gas again
by eljefino
07/24/16 08:29 PM
CV boots ripped on Chevy Blazer
by dlundblad
07/24/16 07:02 PM
Built-in pour spout on Delvac jugs
by fdcg27
07/24/16 06:45 PM
Mobil 1 question
by Moondawg
07/24/16 06:36 PM
Mold & Moisture Resistant Drywall
by Warstud
07/24/16 06:36 PM
FRAM EG 3614, 5,000 miles, CUT OPEN
by car51
07/24/16 06:25 PM
FRAM XG2, 10,xxx miles CUT OPEN
by car51
07/24/16 05:33 PM
MC FL-820S, 7.6K miles, 2012 F-250
by car51
07/24/16 04:41 PM
NJ1911, SneakyTacos, DaveD, 8o8is, Texasdude74
58584 Registered Users
112 registered (182RG, 2015_PSD, 4WD, 69GTX, 901Memphis, 7 invisible), 1792 Guests and 14 Spiders online.
58584 Members
66 Forums
252208 Topics
Page 5 of 5 < 1 2 3 4 5
#3135876 - 09/25/13 06:16 PM Re: Seizing caliper? [Re: outdoorsman310]
OVERKILL Offline
Loc: Ontario, Canada
Originally Posted By: outdoorsman310
oh i thought you were saying you had drums.
Well I do, but only for the parking brake, LOL smile
02 Expedition
06 Charger R/T
14 Charger SRT-8
#3136588 - 09/26/13 11:56 AM Re: Seizing caliper? [Re: OVERKILL]
Vikas Offline
Loc: NorthEast
Yes, his high performance BMW M5 had a special option for the rear drum brakes and he paid extra for it. Besides, calipers are really difficult to engineer on a drum brake system but since this is a BMW, anything is possible.
#3334272 - 04/05/14 04:52 PM Re: Seizing caliper? [Re: Tegger]
SubLGT Offline
Loc: Idaho
Originally Posted By: Tegger
Originally Posted By: Vikas
Pricey Syl Glyde? Ask Tegger on the price of Molykote M77!
My 2.6oz jar was $75. That jar measures 2" in diameter and is 2" tall.
Honda Canada's TSB says they now have some really good pricing from their supplier, so the current prices are probably lower than what I paid.
Sil-Glyde is very cheap by comparison to M-77; but Raybestos does make a competing silicone-based brake grease that is close to M-77 in price.
A 1oz jar of Molykote M77 is around $17 at Amazon
http://www.amazon.com/Corning-Molykote-Lubricant-Silicone-Container/dp/B00B3URP1I
#3334299 - 04/05/14 05:23 PM Re: Seizing caliper? [Re: OVERKILL]
Merkava_4 Offline
Loc: Clovis, CA
Sounds like it's not releasing all the way. Either a collapsed brake hose or the caliper is partially froze.
#3334655 - 04/06/14 12:22 AM Re: Seizing caliper? [Re: OVERKILL]
Gokhan Offline
Loc: Los Angeles, California
In case you want to try it, rebuilding the calipers is fairly easy. I rebuilt them with the OEM kit from the dealer. I used some rubber hose on a screw driver and plugged it into the union nut to prevent the union nut from leaking the brake fluid when caliper is removed; so, I didn't have to run out of fluid and bleed the master cylinder. To push the pistons out, I just tapped on the brake pedal -- no compressed air was needed. You clean everything and lube with brake fluid and also glycol grease if provided in the kit. Lube the bushings with brake grease.
The only somewhat tricky part is installing the dust boot. Just make sure that you don't forget the old snap ring inside and install the new boot and snap ring properly -- with the correct orientation of the boot and snapping things into correct grooves.
1985 Toyota Corolla LE, 4A-LC engine, ~ 264,000 M
Mobil 1 (M1) 0W-40 SN synthetic
Toyota 90915-YZZF2 filter, 90430-12031 drain gasket
#3335090 - 04/06/14 04:27 PM Re: Seizing caliper? [Re: OVERKILL]
hattaresguy Offline
Loc: CT
I'd still do a full brake fluid flush with ATE DOT 4 fluid.
I'm still in utter shock an M5 that could see track time wouldn't recommend seasonal or at least every two year brake fluid flushes. Well I guess BMW started the no service lease nonsense a long time ago!
Edited by hattaresguy (04/06/14 04:29 PM)
