Pirelli
by borgward
05/29/16 02:10 PM
'88 Cadillac smog (Emission test) fails
by momo
05/29/16 01:59 PM
Towing what to look for?
by Camprunner
05/29/16 01:48 PM
The Critic's Choice 2014 Yaris vs 2015 Accent
by Gasbuggy
05/29/16 12:52 PM
What Fram Ultra For 95 Cadillac Seville?
by crazyoildude
05/29/16 12:46 PM
Import Multi-Vehicle, Valvoline vs. Castrol, VI?
by Samzone
05/29/16 12:36 PM
Fram Ultra Bypass Valve Spring Life
by Digital2k2
05/29/16 11:32 AM
CARQUEST Filters are now made by Purolator (pics)
by sir1900
05/29/16 11:03 AM
Small 4 Cycle Engines, longevity tips
by henni
05/29/16 10:05 AM
Car won't star after new serpentine belt
by AlaninPA
05/29/16 09:06 AM
Was this sold by Costco?
by Vikas
05/29/16 09:03 AM
Gas or lithium-ion powered string trimmer?
by skyactiv
05/29/16 08:41 AM
Moutainman31282, AlaninPA, z0bug33, smitty31, jimshep
58013 Registered Users
64 registered (123Saab, Astro_Guy, bdcardinal, 4wheeldog, Bandito440, 8 invisible), 1660 Guests and 322 Spiders online.
58013 Members
66 Forums
249560 Topics
#3334524 - 04/05/14 09:33 PM Has anyone had bypass pipe stuck to water outlet?
Gokhan Offline
Loc: Los Angeles, California
I had a leak at my water-outlet gasket and started the job of replacing the gasket today. In fact, there was hardly any gasket left.
I wanted to remove the water outlet, which requires removing it from the water-bypass pipe and replacing the O-ring for it. There is one small bolt holding the water-bypass pipe's flange against the water outlet and I removed it. For some reason, the flange of the water-bypass pipe appears almost welded to the water outlet. No matter how hard I pull or twist it, I can't separate them. Below is the parts diagram, with the outlet, gasket, O-ring, and the flange end of the bypass pipe shown at the top left:
Has anyone had this problem? I wanted to remove the water outlet from the water-bypass pipe because it's hard to scrape the old gasket material otherwise, as there is little space between the water outlet and cylinder head.
1985 Toyota Corolla LE, 4A-LC engine, ~ 263,000 M
Mobil 1 (M1) 0W-40 SN synthetic
Toyota 90915-YZZF2 filter, 90430-12031 drain gasket
#3334586 - 04/05/14 10:29 PM Re: Has anyone had bypass pipe stuck to water outlet? [Re: Gokhan]
Chris142 Offline
Loc: apple valley, ca
Probly lots of corrosion holding them together
02 Wrangler super-s 10w30
87 F250 delo 15w40
04 Tahoe super-s 5w30
Z400 Lucas 10w30
KLR250 Maxima 10w40
Can am maveric delo 5w40
