That's unfortunate...or maybe bypass filtration?
by linksep
06/27/16 02:24 AM
Over Oiling
by mjoekingz28
06/27/16 12:59 AM
Sweden Trials Electric Higway for Trucks
by Y_K
06/27/16 12:07 AM
17 yo deutsch filter?
by robo339
06/26/16 11:07 PM
Ford Focus wrecked
by tig1
06/26/16 10:13 PM
Valvoline Maxlife vs Supertech Synthetic vs QSED
by mazdamonky
06/26/16 09:56 PM
Lexus seats in a Camry
by Nick1994
06/26/16 09:52 PM
shop rechecking work after front end parts replace
by motor_oil_madman
06/26/16 09:50 PM
M1-EP vs vanilla M1
by Atomic
06/26/16 09:29 PM
Supertech Synthetic and Citgo
by RRLJR
06/26/16 09:28 PM
Gun Belt Wanted
by FirstNissan
06/26/16 08:24 PM
car wash soap for pressure washer
by Donald
06/26/16 08:16 PM
Josh_Westwood, Brogan, Superlatives, Ruturaj, derfderfgoose
58280 Registered Users
25 registered (car51, Brad_C, Axe Man, dino33, 2 invisible), 780 Guests and 11 Spiders online.
58280 Members
66 Forums
250856 Topics
#3334524 - 04/05/14 09:33 PM Has anyone had bypass pipe stuck to water outlet?
Gokhan Offline
Loc: Los Angeles, California
I had a leak at my water-outlet gasket and started the job of replacing the gasket today. In fact, there was hardly any gasket left.
I wanted to remove the water outlet, which requires removing it from the water-bypass pipe and replacing the O-ring for it. There is one small bolt holding the water-bypass pipe's flange against the water outlet and I removed it. For some reason, the flange of the water-bypass pipe appears almost welded to the water outlet. No matter how hard I pull or twist it, I can't separate them. Below is the parts diagram, with the outlet, gasket, O-ring, and the flange end of the bypass pipe shown at the top left:
Has anyone had this problem? I wanted to remove the water outlet from the water-bypass pipe because it's hard to scrape the old gasket material otherwise, as there is little space between the water outlet and cylinder head.
1985 Toyota Corolla LE, 4A-LC engine, ~ 264,000 M
Mobil 1 (M1) 0W-40 SN synthetic
Toyota 90915-YZZF2 filter, 90430-12031 drain gasket
#3334586 - 04/05/14 10:29 PM Re: Has anyone had bypass pipe stuck to water outlet? [Re: Gokhan]
Chris142 Offline
Loc: apple valley, ca
Probly lots of corrosion holding them together
02 Wrangler super-s 10w30
87 F250 delo 15w40
04 Tahoe super-s 5w30
Z400 Lucas 10w30
KLR250 Maxima 10w40
Can am maveric delo 5w40
