Disclaimer: Pics are all [censored] cell phone pics with bad lighting. I don't break out the good camera with greasy hands.
the deck after another 4 hours of hard labor
you have to totally tear the hub/spindle assembly down to regrease ... even then they are sealed bearings.
Spoiler:
hub's are 44$ naked or 97$ loaded(with 2-snapring, spacer 2-bearings)
Spindles are 34$ each
bearings 8.50$ each -2 per spindle
can of yellow spray paint in AG yellow 9.90
Bushing for idler armof tensioner pulley 3$
All new stainless steel hardware = about 25$
New tension spring = 19$
New Deck belt = 35$
new pto belt = 25$
I proceeded to tear down, Had to hammer a socket onto 2 of the bolts to get the blades off..
Getting new bolts.
2 of the circles on the spindles are abit off(what the blades center on) but its somewhat of an optical illusion. Measured they are ok to reuse. Which is good because they are 34$ each.
Deck has 3 of everything.
Proceeded to removing pulleys via not so BFG(2.5lb mini-sledge) with a block of wood and a punch.
Then had to pound out the spindles.. this is by no means an exhaustive list of steps. I don't want to write a book.
Left and right Hub assembly were dry and gross. Looked like dog hard poop with rust seasoning.
We wont mention the jobs of carriage bolts and stripped shoulders here
Hub after teardown still has the mid snapring in covered with "grease"
Note: used a punch to knock the bearings out .. one from top .. one from bottom.
working on the 3rd spindle(middle one) it wasnt moving.
Suddenly it moved about 1/4" (hammering it)
uh oh... hint only one snapring in this pic.
Yep New hub time
I decided not to try to weld the very porous cast that had broken into 3 pieces not to mention you have to press the bearings through that opening.
Damaged hub
Will update after it gets cleaned up painted.. and fresh parts... oh and by a stroke of luck the hub bring replaced is the one with the stripped shoulders---where the carriage bolts go to prevent them from turning
Oh also welding the deck its cracked on both sides of the front roller...
PS: If I used the wrong word in this post somewhere I'm assuming you can figure out what I meant. Already edited it 4x
.. what happens when you post after 14 hours of work.
