Industrial hand cleaners?
by KenO
07/26/16 11:58 PM
Shell Rotella T6 in a Altima 2.5
by Grambo
07/26/16 11:24 PM
"Creaking" Conti DWS's?
by Lolvoguy
07/26/16 10:52 PM
Check your car after it's been worked on
by Nick1994
07/26/16 10:15 PM
How are lg android devices now days?
by ram_man
07/26/16 09:42 PM
Dexos 5w30 with highest 100°c Viscosity
by CapitalTruck
07/26/16 09:32 PM
How do you avoid being perceived as a rookie when
by motor_oil_madman
07/26/16 09:27 PM
Oil opinions after dumping FF
by JoelB
07/26/16 09:27 PM
Bulk loading a grease gun?
by buck91
07/26/16 08:59 PM
Sears Battery Pricing
by PeterGreen
07/26/16 08:29 PM
My 12am emergency strut spring repair on a Civic
by Colt45ws
07/26/16 08:19 PM
My upper sidewall pinehole leak fix
by Pokermatters
07/26/16 07:52 PM
snydercn, surfbum, Tmemz4, woollum86, Phil108
58612 Registered Users
20 registered (chrisri, car51, bbhero, Boczech, flanso, 2 invisible), 849 Guests and 13 Spiders online.
58612 Members
66 Forums
252296 Topics
Page 1 of 2 1 2 >
#3334212 - 04/05/14 03:31 PM THREE Permatex brake lubricants
sws669 Offline
Loc: Hawaii
Why three? Any preference? Only want to buy one type. TIA
Permatex Ultra Disc Brake Caliper Lube
file:///C:/Documents%20and%20Settings/HAL/My%20Documents/Downloads/20353.pdf
Permatex Ultra Disc Brake Caliper Lube, Silicone/Moly Formula
file:///C:/Documents%20and%20Settings/HAL/My%20Documents/Downloads/24115.pdf
Permatex Ceramic Extreme Brake Parts Lubricant
file:///C:/Documents%20and%20Settings/HAL/My%20Documents/Downloads/24125%20(1).pdf
Edited by sws669 (04/05/14 03:32 PM)
#3334219 - 04/05/14 03:40 PM Re: THREE Permatex brake lubricants [Re: sws669]
yonyon Offline
Loc: NJ, USA
A file:// URL only works on your own computer. None of us here can see what you're linking to except for...
LOOK OUT! BEHIND YOU!
#3334233 - 04/05/14 04:01 PM Re: THREE Permatex brake lubricants [Re: sws669]
JHZR2 Offline
Loc: New Jersey
None. Buy 3m silicone paste and then either the m77 or crc silaramic if you need some with solids.
#3334235 - 04/05/14 04:04 PM Re: THREE Permatex brake lubricants [Re: sws669]
Joseph_S37 Offline
Loc: Alberta, Canada
Here is the direct link to the Permatex website showing the brake lubes. I'm only seeing two different lubes and a 'brake quiet'
Permatex Brake Lubes
From the descriptions it seems the Extreme might be a higher end formula where as the Ultra is their 'normal' formula?
Hopefully someone with experience using both can chime in
Edited by Joseph_S37 (04/05/14 04:05 PM)
2013 F-150 5.0L 51,500km
Penz Platinum 5W-20 || Fram XG10575
#3334237 - 04/05/14 04:07 PM Re: THREE Permatex brake lubricants [Re: sws669]
NHGUY Offline
Loc: USA
I would use the CRC black colored Sta Lube stuff.
#3334253 - 04/05/14 04:30 PM Re: THREE Permatex brake lubricants [Re: sws669]
sws669 Offline
Loc: Hawaii
#3334267 - 04/05/14 04:48 PM Re: THREE Permatex brake lubricants [Re: sws669]
Merkava_4 Offline
Loc: Clovis, CA
Get the GREEN Permatex Ultra. Awesome slide pin lube.
#3334284 - 04/05/14 05:06 PM Re: THREE Permatex brake lubricants [Re: sws669]
sws669 Offline
Loc: Hawaii
Agree, I've used the Ultra green for the slider pins before. Had a strong brake pull and rebuilt both calipers and replaced brake hoses to no avail. Bought new NAPA Total Eclipse calipers that solved the pull but now have a very loud squeak. I'll try the green lube on the hardware and piston/ rear pad contact points. Thanks.
#3334900 - 04/06/14 11:21 AM Re: THREE Permatex brake lubricants [Re: NHGUY]
Trav Offline
Loc: MA, Mittelfranken.de
Yep i am back to this also. I tried many and nothing seems to do better than this so far.
#3335884 - 04/07/14 02:58 PM Re: THREE Permatex brake lubricants [Re: sws669]
dubie2003 Offline
Loc: Melbourne, Florida
I just did the brakes on my truck. I used the Green on the slide pins and the purple on the back of the pads. Works thus far with zero squeeks.
Now that I typed that, it will probably squeek.....
The best deal I found was buying the plastic can at AAP with online discount codes (stacking mrrebates on it too).
#3338712 - 04/10/14 11:57 AM Re: THREE Permatex brake lubricants [Re: sws669]
2008wrx Offline
Loc: CA
I use this: NAPA Sil-Glyde Silicone Lubricating
#3340841 - 04/12/14 05:20 PM Re: THREE Permatex brake lubricants [Re: sws669]
SLCraig Offline
Loc: London, ON, Canada
I used the green stuff on my Saturns back in the day, and wondered why I needed to service my brakes every 6 months until I realized the green stuff was swelling and ruining my slide bushings. The stuff is USELESS around rubber and it creates more headaches than it helps.
I have been using Sil Glyde ever since on any and every car I've touched and it works every time.
Would not use that green [censored] as long as I live anymore.
The other 2 types I have no experience with.
2010 Civic SI sedan 6MT
SynPower 5w30 | Fram Ultra | Pennzoil MTF
#3346435 - 04/18/14 11:16 AM Re: THREE Permatex brake lubricants [Re: sws669]
nthach Offline
Loc: California
I never had luck with Permatex brake lube. I use Molykote M77 on the backs of the pads and either Sil-Glyde or Toyota red rubber grease on slide pins.
#3356283 - 04/28/14 10:25 PM Re: THREE Permatex brake lubricants [Re: SLCraig]
AMC Offline
Loc: South Eastern, CT
I too went through the headache of the green synthetic brake lube. I tried sil-glyde and and never looked back. It works great and is very versatile. I use anti-seize compound on the brake pad ears and backs, works well for me. No squeeks at all
11 Chevy Silverado - PP 5w-30
10 Ford Focus - WH 5w-20
14 Yamaha Super Tenere - Delo 15w-40
1oz TCW-3 Per 5 Gallons of Fuel.
#3360508 - 05/03/14 08:18 AM Re: THREE Permatex brake lubricants [Re: NHGUY]
Petersubaru Offline
Loc: Canada
…This product would work with most cars…but not with my '01 subi..it reacts with the rubber to cause slider pin seizing …
Page 1 of 2 1 2 >
