Looking for info on two quick spray waxes.........
by demarpaint
05/01/16 04:43 AM
The Heroin Epidemic In The U.S....
by qwerty1234
05/01/16 01:28 AM
Air filter wrap
by Duffyjr
04/30/16 10:21 PM
15W-40 Delo, Delvac or Rotella For KUBOTA turbo
by pburchett
04/30/16 09:50 PM
Traveler synthetic oil a slow seller?
by Electromotive
04/30/16 09:34 PM
Tyre rubber, methanol, and bore wear
by Shannow
04/30/16 09:34 PM
What to use in 99 Buick Lesabre OCI?
by Duffyjr
04/30/16 09:26 PM
Help w/Transmission Drain/Fill 08 Honda CR-V 4wd
by klt1986
04/30/16 08:58 PM
pennzoil ultra platinum pure plus
by Brayden
04/30/16 08:10 PM
Group 5 synthetic oil
by Brayden
04/30/16 08:07 PM
Pennzoil Ultra platinum at Walmart
by RubentheIowan
04/30/16 08:03 PM
G-05 Change intervals, 3 or 5 years?
by Canadastang
04/30/16 08:03 PM
Doxxy, Jetstreamz06, TalNum, Spinnizle, JustinL
57758 Registered Users
52 registered (Bandito440, bmod305, BobFout, bbhero, AirgunSavant, BobsArmory, 1 invisible), 801 Guests and 93 Spiders online.
57758 Members
66 Forums
248282 Topics
#3333860 - 04/05/14 06:42 AM Wynn Fuel System Tune up VS DIY FST?
Aurora09 Offline
Loc: Saint Clair, MI USA
Today I bought a 2008 Saturn Aura XR from my local Ford Dealer, Northgate Ford. It has the 3.6 liter DOHC V-6, according to the specs I found online it has 252 horsepower and 250 ft.-lb torque @3,000 rpm so it should be my fastest car yet, assuming its lighter than the Aurora. It is being inspected and prepped for me and a free OC before I pick it up next week. There is a small dent on the driver door. He offered to fix it, but rather than do so I was gonna use it to take a few hundred dollars off the final price. OR I could ask them to do the Wynn fuel system service FST for me. I could easily do this myself. I put a bottle of techron in the tank, clean the MAF sensor, clean the throttle body, replace the PCV valve, clean the IAC valve (if equipped), run half a can of either seafoam spray or liquid (possibly both, depending on the results), replace the air filter, and inflate the tires to the proper pressure. Once I start the car again after the seafoam soaks in, I head out for a spirited run in 2nd gear, 30-70 MPH about ten times. My real question is should I use the wiggle room that the dent gives me to have them throw in a Wynn FST, or do it myself and have them change the trans fluid and filter for free, possibly a full flush, and change the filter myself shortly afterwards? Or do all of it myself and have them fix the dent? I don't know if the Wynn FST is better than DIY methods because I've never had a car actually get to the point of actually needing it, since I usually do seafoam in the spring and the other items as needed.
#3333868 - 04/05/14 06:58 AM Re: Wynn Fuel System Tune up VS DIY FST? [Re: Aurora09]
datech Offline
Loc: us
I usually just inflate the tires. I didn't know I need all that other stuff. Actually I just keep the tires inflated all the time, as I drive enough that I need the tires ready to go at any time.
Do you need to change the plugs after you run all this stuff?
#3333871 - 04/05/14 07:02 AM Re: Wynn Fuel System Tune up VS DIY FST? [Re: Aurora09]
Char Baby Offline
Loc: Western NY
I would have them fix the dent. In my area of the country, any panel ding/dent is at least(AT LEAST) $450 per panel and, if done properly, they'll blend/match panel color meaning, the body shop will also spray into the next panel(s) so that the paint & body work looks uniform.
You'd never know if they actually preformed the Wynn FST especially if the engine doesn't run poorly but, the body work you won't be able to miss!
And, unless you also do body repair/paint work, the other maintenance can be performed by you as mentioned. JUST MY OPINION! smile
Edited by Char Baby (04/05/14 07:06 AM)
"Retired"
'80 Firebird FORMULA V8/4bbl-NEW
'06 Mazda 3i 2.0L-Pre Owned
'15 Nissan Altima 2.5 SV-CPO
Still looking for a car for my wife(new, used, CPO)
#3333886 - 04/05/14 07:38 AM Re: Wynn Fuel System Tune up VS DIY FST? [Re: datech]
Aurora09 Offline
I wouldn't do it if I had just changed the plugs, for fear of dirt jamming them up, but I recently ran about a quarter of a can of seafoam through the air intake of a John Deere LX188 with a spray bottle. It didn't stall for the rest of the season. When I changed the spark plugs later on, the firing surfaces were whitish, and the rest of it was brownish black. I would say it cleaned the spark plugs. Since the car has 97,000 miles, I'm just gonna put in new plugs soon anyway.
1994 Jeep Grand Cherokee Laredo. 4.0 six cylinder. 266,000 miles. Fram orange filter, service pro 10W30 oil.
#3333905 - 04/05/14 08:01 AM Re: Wynn Fuel System Tune up VS DIY FST? [Re: Aurora09]
double vanos Offline
Loc: Bisbee, Arizona
Fix the dent, if the car runs good right now, just use top tier gas and use Techron fuel system cleaner before your next oil change. That should get it.
It's probably just me, but I wonder sometimes about all these whiz bang products you see now a days
Svetlana Kapanina is harder core than Sabine Schmitz.
www.kapanina.com
#3333968 - 04/05/14 09:23 AM Re: Wynn Fuel System Tune up VS DIY FST? [Re: Aurora09]
FL_Rob Offline
Loc: gulf coast FL.U.S.
Dent approved
#3334101 - 04/05/14 12:31 PM Re: Wynn Fuel System Tune up VS DIY FST? [Re: Aurora09]
Aurora09 Offline
Update: I asked them just to fix the dent. It'll give me some extra work to get it running "perfectly" lol.
#3334761 - 04/06/14 08:16 AM Re: Wynn Fuel System Tune up VS DIY FST? [Re: Aurora09]
Char Baby Offline
Loc: Western NY
Very Good! smile
"Retired"
