Anyone remember "in living color" ?
by car51
12 minutes 13 seconds ago
schedule / oil recom. for 2015 Honda Accord V6
by Viche
48 minutes 19 seconds ago
looking for a good garden hose reel
by bowlofturtle
Today at 02:03 PM
New WD Blue 2.5" hard drive beeps???
by Drew99GT
Today at 12:39 PM
Grease for Craftsman Snow Thrower
by GGorman04
Today at 11:19 AM
Napa syn $2.99 qt.
by pda1122
Today at 10:59 AM
Can you mix brands of DOT 4 brake fluid?
by enochian
Today at 10:50 AM
rust on stainless steel pool rail and ladder
by raaizin
Today at 10:50 AM
Anybody have experience with Lubrication Engineer
by gmh101357
Today at 10:43 AM
Oil for a ford 302
by mazdamonky
Today at 10:37 AM
93 mercury sable unlock steering wheel
by cptbarkey
Today at 10:24 AM
Ford F250-350 Interstate MPG with the 6.2L Gasser
by AirgunSavant
Today at 10:12 AM
stydel311, jackadf, rlb4, apenland01, 2ManyMiles
57767 Registered Users
98 registered (2oldtommy, 901Memphis, 2010Civic, 4ever4d, 1foxracing, alarmguy, 11 invisible), 2000 Guests and 338 Spiders online.
57767 Members
66 Forums
248370 Topics
Page 2 of 2 < 1 2
#3331390 - 04/02/14 01:03 PM Re: What straight wt oil to try for 2000 RHD Cherokee [Re: Raye7r]
Papa Bear Offline
Loc: Leamington, ON, Canada ..... r...
Originally Posted By: Raye7r
The oil light started coming on this winter.
Does it knock? Is it running OK?
If it's running alright then leave it alone and drive on.
I never was too bright - now old age and forgetfulness complicate things as well" crazy
2016 Dodge GC deep cherry CVP drive
#3331536 - 04/02/14 03:51 PM Re: What straight wt oil to try for 2000 RHD Cherokee [Re: Raye7r]
Raye7r Offline
Loc: Indiana
I'v changed the sender twice, it has a gauge also. Will have checked with mechanical gauge. Light just started coming on. Mail delivery vehicle so has a ton of idling time on it (5 hours to a hundred miles). Just called my NAPA and told them to bill me for a case of 15w50. No rattles, even when light on. Rattles good on startup though. Been a good one. You think new oil pump will help if pressure low.
#3331582 - 04/02/14 04:57 PM Re: What straight wt oil to try for 2000 RHD Cherokee [Re: Raye7r]
eljefino Offline
Loc: ME
You guys are on the wrong track with the right idea. wink
OP needs to either pull his thermostat or put in a 150-160 degree one. This will thicken up the oil more than going up a grade. Those jeeps have a mechanical and electric fan, IMO. Wire up the electric to be always on.
#3331675 - 04/02/14 07:01 PM Re: What straight wt oil to try for 2000 RHD Cherokee [Re: Raye7r]
bullwinkle Offline
Loc: Cincinnati, OH, USA
20W50 and a can or two of STP will raise it-but verifying actual low oil pressure would be a smart move.
06 Ram 3500 CTD 4X4(FG Venturi), 93 GMC C3500 6.2, 89 F-450 7.3, 98 XJ 4.0(XG8A), 05 xB(XG3600), 15 Transit 3.7, 03 Merc Grand Marquis 4.6 2V(CQ Blue)
#3332068 - 04/03/14 08:51 AM Re: What straight wt oil to try for 2000 RHD Cherokee [Re: Raye7r]
rslifkin Offline
Loc: Rochester, NY
On a 2000, the head probably cracked when it got hot (0331 head). Has it been losing coolant? If so, the bearings in the bottom end are probably shot if it's got low oil pressure, as the coolant has likely wiped them out.
If the oil isn't milky, no slime under the oil cap and it hasn't been losing coolant, then verify the pressure with a mech gauge and replace the oil pump if it's actually low (worn out oil pumps aren't uncommon on high mileage 4.0s).
Edited by rslifkin (04/03/14 08:52 AM)
1998 Jeep Grand Cherokee 5.9 Limited with lots of mods (206k miles, bought with 100k in 1/2010)
Rotella T6 @ 6k OCI
#3332125 - 04/03/14 09:42 AM Re: What straight wt oil to try for 2000 RHD Cherokee [Re: rslifkin]
jeepman3071 Offline
Loc: Storrs, Connecticut
This. thumbsup
2000 Jeep Cherokee Sport 4.0L (163k) - Pennzoil HM 10w30, Napa Gold 1516, Magnefine trans filter
#3332273 - 04/03/14 12:36 PM Re: What straight wt oil to try for 2000 RHD Cherokee [Re: Raye7r]
Miller88 Online   content
Loc: Onondaga County
A lot of times, 4.0s will run hot enough to evaporate the coolant so you don't end up with the milk on the oil cap ... even with a cracked head.
Originally Posted By: 01rangerxl
A Lada with manually adjusted drum brakes sounds like a fantastic car.
#3332280 - 04/03/14 12:42 PM Re: What straight wt oil to try for 2000 RHD Cherokee [Re: Miller88]
rslifkin Offline
Loc: Rochester, NY
Huh. When my mom's cracked the head, it had almost a 1/2" of slime under the valve cover and on the oil cap and valvetrain after a couple hundred miles (she noticed it losing coolant, I checked it out and found it before any lasting damage was done). It took forever to clean it all up before reassembly.
Rotella T6 @ 6k OCI
#3332443 - 04/03/14 03:15 PM Re: What straight wt oil to try for 2000 RHD Cherokee [Re: Raye7r]
Donald Offline
Loc: Upstate NY
Have you changed the oil filter since the light started to come on? If not that would be the first thing to do.
I had a 1994 Camry where the oil light would come on. Mechanical gauge confirmed oil pressure issues. Changed only the filter (Amsoil) and problem went away. Amsoil evaluated the filter and said the filter was full, but not defective. So unknown problem with a top quality filter.
Put on another 100K miles and never any more issues.
2015 Ford F250 w/Powerstroke
2001 Jeep Grand Cherokee Laredo 4.0- 4-sale
1999 Dodge Ram 2500 w/Cummins- 4-sale
#3332806 - 04/03/14 09:54 PM Re: What straight wt oil to try for 2000 RHD Cherokee [Re: Raye7r]
artificialist Offline
Loc: Florida
If you really need an SAE40, you can probably get it at a marina because many boats still have a Detroit Diesel 2-cycle engine which needs SAE40.
I wouldn't use STP, approved oil already has the additives that are needed.
2010 Lancer Ralliart Sportback
#3333343 - 04/04/14 02:27 PM Re: What straight wt oil to try for 2000 RHD Cherokee [Re: Raye7r]
circuitsmith Offline
Loc: Wash, DC
If it's not the sender it's most likely worn main crank bearings causing low pressure at idle.
How many of you saying change the oil pump have actually seen a high mileage & low pressure problem fixed with a new pump?
The pump is low, closest to the sump so it's the last part to get starved of oil.
Normally it's constantly bathed in the oil at its coolest.
2006 Toyota Matrix 5-sp. 1zz-fe 5000mi/12mo OCI
Any major brand dino 5w-30 on sale
#3333467 - 04/04/14 04:42 PM Re: What straight wt oil to try for 2000 RHD Cherokee [Re: Raye7r]
andyd Offline
Loc: Marshfield , MA
The rattle on cold start up. Thats a worn thrust bearing on the crank. It prolly has a few miles left.But it is showing wear. I would switch to 20 w 50. I use it down to 10F in my cars which are specced for it.
1988 BMW 528e 20w50 dino, STP filter
'09 Camry SE, Valvoline bulk 5w30 and ? filter
Page 2 of 2 < 1 2
