Chevron & Sunoco & Speedway $100 Gift card $92
by gojoneeded
29 minutes 45 seconds ago
Santa's Not Going To Be Happy
by Warstud
42 minutes 11 seconds ago
can someone explain the Ecoboost to me?
by columnshift
Today at 07:50 PM
4 dragging weak brakes (after parked for a year)
by columnshift
Today at 07:34 PM
New S&W Shield 9
by funflyer
Today at 06:42 PM
ecoboost 3.5
by boostnation
Today at 06:30 PM
Meijer, Mobil and the joys of Labor Day stackation
by fdcg27
Today at 06:25 PM
BMW electrical system pretty good
by fdcg27
Today at 05:59 PM
The top makes the policy ...
by HTSS_TR
Today at 05:36 PM
Dodge 318 oil?
by chartrue2
Today at 05:04 PM
Fram Ultra XG3506 - 2 years/11,000 miles Cut Open
by Nick1994
Today at 04:39 PM
Genesis G70 spy photos
by HTSS_TR
Today at 04:17 PM
pperras01, Grabberblu, Dave_PPE, davebe, Logos
58964 Registered Users
113 registered (74Scout, Bandito440, 4WD, 2015_PSD, asiancivicmaniac, ARB1977, 11 invisible), 1636 Guests and 9 Spiders online.
58964 Members
66 Forums
253786 Topics
Page 2 of 2 < 1 2
#3333224 - 04/04/14 11:53 AM Re: Honda K series cam galling issue.... [Re: gregk24]
ARCOgraphite Offline
Loc: N.H, U.S.A.
The engine in our '91 civic was garbage. As was the new ignition coil in cap defective by poor design. ( I still have that garbage cap on my owrkbench!) The wifes 85 mitsu colt 1.5 was a MUCH better engine comparing $7500 new car price point back in the day.
2014 Nissan Rogue S CVT, OC#4 19671mi-Castrol EDGE EP 5W30+Nissan 15208-9E01A Filter
2015 Forester 6MT 5Door, OC#6 41243mi-M1EP 0W20+Subaru Filter
#3333372 - 04/04/14 02:54 PM Re: Honda K series cam galling issue.... [Re: gregk24]
propuckstopper Offline
Loc: MB, Canada
If you read the entire thread, you will see that I indeed changed out the camshaft and all the roller rockers. The noise continued, and still does to this day.
Here is the weirdest thing: when started ice cold, this engine is WHISPER quiet. There are no noises whatsoever. After about a minute of idling, it starts ticking. There is no way this is a case of the oil viscosity changing, as the engine has not run long enough to heat the oil significantly.
Believe me, I have had some very top-notch engine builders listen to this Element engine, and they are all equally stumped. One guy suggested that maybe the noise is in the VTEC system somewhere, although I have changed the filters in there and nothing looked abnormal.
Here is a post I did on the Honda Element forum, for those that are interested.
http://www.elementownersclub.com/forums/showthread.php?t=57922
1965 Pontiac GTO Tri-Power 4-Speed Hardtop (Montero Red)
1968 Pontiac GTO Covertible 400 H.O./Auto (Solar Red)
2000 Lexus ES300
2003 Honda Element AWD
#3333707 - 04/04/14 10:21 PM Re: Honda K series cam galling issue.... [Re: propuckstopper]
gregk24 Offline
Loc: FL, USA
I will ask again, when your engine is at operating temp does the noise go away? Because my engine is also whisper quiet for a minute UNTIL IT IDLES DOWN then the piston slap begins. It sounds similar to your video, BUT it goes away once warmed up. And I dont mean when the coolant warms up, I mean after a good 10 minutes of driving or more.
2012 Honda Accord EX-L
Taffeta White - Ivory
40,xxx miles
PPPP 0w20 / Fram Ultra
#3333733 - 04/04/14 10:47 PM Re: Honda K series cam galling issue.... [Re: gregk24]
Loc: MB, Canada
Here is exactly how this goes. Stone cold engine gets fired up and there is no noise whatsoever. When it idles down, it begins to tick.
Once it starts ticking, it is there for good. Five minutes or five hours of driving, the ticking remains.
2000 Lexus ES300
#3333756 - 04/04/14 11:14 PM Re: Honda K series cam galling issue.... [Re: propuckstopper]
gregk24 Offline
Loc: FL, USA
Got it, so its certainly not piston slap.
40,xxx miles
#3333829 - 04/05/14 04:28 AM Re: Honda K series cam galling issue.... [Re: Miller88]
bruno Offline
Loc: new Jersey
Ever hear of BMW M Series ?
#3334789 - 04/06/14 08:49 AM Re: Honda K series cam galling issue.... [Re: gregk24]
Loc: N.H, U.S.A.
Again, maybe the VCT is not assembled properly. Then you have wrist pin sizing and rod clearances, oil restrictor orifice not replaced after rebuild, transmission flex plate and bolts, etc,
Edited by ARCOgraphite (04/06/14 08:49 AM)
#3334962 - 04/06/14 01:06 PM Re: Honda K series cam galling issue.... [Re: gregk24]
Highkm Offline
Loc: Ontario, Canada
I have a 2003 accord 4cyl. I notices cam lobe galling and pitting around 300K. Dealership foreman indicated the cams need replacement. I sent the oil sample to a lab that indicated nothing of concern regarding metallic composition of the oil sample. So I continued driving. Just around 590K timing chain stretched about 0.5 CM and threw an engine light. While changing the chain I inspected the cam shafts with focus on the lobes. They looked similar to when they were 300K. So no concerns. I am 606K now. The valves are due for adjustment to reduce the noise. If you experience the valve noise it does not indicate pending engine problems. It is good to hear it a bit because it means they close properly. Otherwise they will burn out. Engine consumes 1L of 0W20 every 3800 to 4200 KM combined driving. I use Amsoil 0W20 in the winter and 5W30 from April to November (South Ontario). I do a complete drain with filter replacement every 25K. The info I posted is so that you all can compare and lay your concerns to rest. Use good synthetic oil and oil filter and don't worry for 500K. If your car sits for months without running the engine periodically the cam shafts as well as other engine components become dry. If that's your case, put molyslip E oil additive. It coats the metal and stays there for at least until your next oil drain and fill. It saves the cam lobes as well as cylinder walls during dry starts. This piece of information is also confirmed by Amsoil support line. Happy driving!
#3335002 - 04/06/14 01:53 PM Re: Honda K series cam galling issue.... [Re: gregk24]
Gokhan Offline
Loc: Los Angeles, California
That seems like a lot of consumption, even for that mileage. How did you treat the car? And what weight of oil did you use through its life? Syn, dino?
It's not a lot. The life of valve-stem oil seals depends on their age (years) as well as mileage. For a 15-year-old car, more than a quart per one thousand miles is typical. There is a spring at the circumference of the seal to apply pressure but the synthetic rubber (Viton) in all valve-stem oil seals will harden with age and fail to seal against the valve stem, despite the spring pressure.
If cam wear is an issue, use a quality-brand oil. Thicker oil, more ZDDP, more moly, and other smart additives and smart base stocks may help a little. Going too thick may starve the hard to reach parts of oil though.
1985 Toyota Corolla LE, 4A-LC engine, ~ 264,000 M
Mobil 1 (M1) 0W-40 SN synthetic
Toyota 90915-YZZF2 filter, 90430-12031 drain gasket
Page 2 of 2 < 1 2
